HID Diagnostic Help Needed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by miscrms, Feb 8, 2012.
  1. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    Hi all,
    I could use some help debugging my wife's HIDs on her '08. Got pulled over last week for a drivers headlight out. Assumed a bad bulb as that seems the most common culprit. Ordered the Philips D4R from amazon for $50 and swapped it out via the youtube "10 min" method. All seemed to go well, but after reassembling (and dissembling again and re-reassembling) it still won't fire.
    I guess its possible the new bulb is bad, but I'm wondering what else I should check. Are there voltage points I can check for instance to see that the fuses, relays, ballast etc are functioning correctly? I'll probably try pulling the passenger side bulb and swapping it into the drivers side but I'm hoping there are some easy things to check first before I risk leaving her with no headlights :)
    Only other thing I have noticed is the same drivers side headlight has had some significant condensation inside at times, though its currently dry. We hadn't noticed it going on and off or working intermittently as some others seem to have.
    Thanks,
    Rob
  2. drew935
    drew935 Member
    168
    22
    Nor Cal
    I would check the ballast and wiring before buying bulbs. If you want, swap the bulbs to the drivers side and see if they fire up. Typically the ballast will die first before the HID bulbs and will kill them as well. How does the bulb look like? Should be pretty clear.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Try the bulb swap both ways. Put the old bulb in the passenger side, and the passenger side bulb in the driver side. That should be definitive of bulb vs. ballast/etc.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I think many folks here w/06-09 Priuses w/HIDs would disagree with you on that, including me.
  5. drew935
    drew935 Member
    168
    22
    Nor Cal
    /\/\ Like I said, typically and I know that it may not be on all cars. ;)
  6. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    If you are a regular reader, you would realize that the ballasts are RARELY the problem.
