HID Headlight Back Cover won't open - any tricks?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by feivel, Oct 21, 2019.
  1. feivel
    feivel Junior Member
    43
    An officer pulls me over to tell me my headlight was out. I discover that the passenger side HID bulb goes out intermittently, and restarts when I power cycle the lights. So I look at PriusChat and find that this is a pretty common issue. Thanks all for being such a great support community! So I watch some videos - should be easy, right?
    I try to open the big round HID cover with the black fins, and... it's really stuck.
    How do you get that cover open? I can't think of a good tool for it. I don't think working lubricant in there is a good idea. Any tricks y'all have found?
  2. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    It is a PITA, the driver's side is worse but change both because the other will start exhibiting the same problem. I got mine (a few times) from EBay, genuine OEM parts and half the cost of what Toyota is going to charge you. Gen II Prii included a 2004 rear ended and totalled in 2012, replaced with a 2009, hit and totalled by someone crossing over the line last Feb. Wife and younger daughter each have a 2006.
    It helps to move the windshield washer tank out of the way a bit. There isn't really a tool other than somehow getting both hands on it so you can push down on one fin with one hand and up on an opposite fin with the other. You can try pushing on a fin where it contacts the cap with a big flat head screwdriver. It takes constant pressure, not sharp banging, there is an O ring in the cap. You are SOL on the driver side, nothing to move out of the way, I hope you don't have big hands ;D
    When it is time to put it back on, you don't have to get it quite so tight. If you have a small "mirror on a stick" put it down there after you get the cap off to see what things look like. You have to pull the silver connector off the back of the bulb then release the 2 clips to get the bulb out. It REALLY helps the first time to see what they look like before you stick your hand in there. Also note the orientation of the bulb when you pull it out, you can touch the glass on the old one but do NOT touch the new one.
  3. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    I've heard that tapping it with a block of wood can break the O ring loose. What I ended up doing was removing the whole module and working with it off the car.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,379
    3,235
    Madison, Wisconsin
    Remove the headlight assembly.
    It is much easier to get leverage and makes it less likely to break the fins.
    Also makes it much easier to remove old bulb and install the new one.
    It takes a bit longer but is well worth it.
