HID Headlight Issues 2005 "Pink Eye"
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by OakdaleMike, Nov 4, 2011.
  1. OakdaleMike
    OakdaleMike New Member
    Oakdale
    My 2005 Prius recently came down with a case of HID Headlight Pink Eye. My left headlight goes on bright white and in a few seconds turns to a pretty purple color light. Not as bright as the white light and real pink/purple color light. So does anyone know if this is a bulb or ballast or control logic or what?
    Thanks...
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I'd start w/the bulb first (keeping the potentially bad bulb) since it's the cheapest.
    Out of curiosity, how many miles are on your car? Do you use them as daytime running lights?
  3. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    How many hours do you have on the bulbs? Or how many miles do you have on the car? When HID bulbs starts to fail they color shift to a bluer or pink color depending on the materials used in their creation. You can eliminate all other variables by simply swapping the offending bulb with the good bulb.
  4. OakdaleMike
    Oakdale
    I have 148,000 on the car now.
  5. cwerdna
    12,544
    2,123
    SF Bay Area, CA
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Bulbs. Time to change them both.
    Tom
  7. OakdaleMike
    Oakdale
    Ok - here is an update. After about a week, the light started to flicker and then it would just go out. So I ordered some replacement bulbs. I paid $12.59 with free shipping for two of the bulbs. I replaced the passenger side bulb tonight and the new bulb seems to work fine. It is a slightly different color, but once I replace the other one, they will look fine. It was hard to get the bulb out - took me about an hour and a half because I was trying to be so careful and everything I tried seemed hard. The new bulb went in in about 10 min. So how come anyone would spend $50 or more on a bulb when I found a pair for $13 bucks? I dont get it. Even if these don't last too long, what a savings! The seller was "Auto Armour" with an ebay store of Auto Armour Car Covers.
  8. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    I can't speak to that seller or the quality of their bulbs but http://www.amazon.com/Philips-Xenon-Headlight-Bulb-Pack/dp/B00480J4KA are currently $33.99 (not the right ones for 06-09 Priuses).
    FWIW, at last check, Toyota wants $150 per D4R bulb only (the ones on the 06-09 Priuses), a reduction from $300.
  9. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Because generic bulbs have lower standards and quailty control compared to oem bulbs. They have a tendency to vary inr color, run hotter, lower output and seating issues that can result in imperfect cutoff lines (when used in a projector style headlight). You get what you pay for. :) In the poor Prius reflector style HID system it probably doesn't matter though.
