HID headlight lights up and then flickers out: Is it the Ballast?
Discussion in 'Gen 2 Prius Technical Discussion' started by wlai, Oct 17, 2021.
  1. wlai
    wlai Junior Member
    36
    Pacific NW USA
    So lately one of my HID headlight will light up, but as I drive it it will flicker out. Turning it off and on relights it but it'll flicker out again.
    Could the HID Ballast cause that behavior? I somehow has the impression that the ballast is only use when the light is first starting up and is subsequently unused once the bulb is already lit.
    Thanks.
  2. Leadfoot J. McCoalroller
    6,837
    6,483
    Pennsylvania
    2018 Prius c
    Sounds more like a level check failure.
    When the headlights start up, the control system is supposed to verify that each lamp's automatic leveling system is functioning correctly. If the leveling system gives a negative response (or no response at all) then the corresponding lamp is extinguished to prevent glare hazards.
