HID headlight replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by IndySteve, May 7, 2011.
  1. IndySteve
    IndySteve New Member
    Has anyone had their HID replaced under the new warranty, extended to five years/50K?
    I had my left one replaced this week, and almost immediately the right one went out. Off and on. Could they have done something to cause this to happen. They didn't replace the ECB; should I demand they do that now?
    Thx.
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    They tend to go out at the same time, typically within a few days/weeks of each other. The ECU/ballast does not usually go bad; that was a common mis-diagnosis from years past, due to the on/off behavior of a dying bulb. My personal opinion of best practices is to replace both bulbs at the same time, and keep the one that still works as an emergency spare. It's kinda funny that Toyota does not do this, since someone coming in under warranty for one bulb will be back shortly for the other, if they don't replace them both to start with.
