HID highbeam mechanism repair
Discussion in 'Gen 2 Prius Technical Discussion' started by blacktouring, Jun 3, 2012.
  1. blacktouring
    blacktouring Junior Member
    45
    Rolling Hills Estates
    I've searched but have been unable to find any useful info on fixing my driver's side HID highbeam. From what I was able to find, I read that there is a mechanism that repositions the bulb when flipping to highbeam. When I engage my highbeams only the passenger side goes to highbeam. Any help would be greatly appreciated.
  2. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    This could be a problem with the solenoid in the bulb, swapping the bulbs over would prove this, but can be difficult if you have large fingers.
  3. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    You might also check your fuses / relays to see if something isn't right. Again, swap left with right and see if the behavior changes.
