HID issues
Discussion in 'Prius c Accessories and Modifications' started by lilzip24, Feb 10, 2015.
  1. lilzip24
    lilzip24 Junior Member
    2014 Prius c
    Hey everyone! I just purchased my 14 Prius C and its the first car ive decided to install HIDs on. I ordered the Kensun H11 Lowbeam set. I hooked them up and they will not turn on at all. The bulbs and ballasts are good because i ran them on my buddies GM pickup battery no problem to verify. Any and all input is appreciated as i have no experience with HIDs.
    #1 lilzip24, Feb 10, 2015
  2. slowpriusj
    slowpriusj Active Member
    167
    271
    Brunswick, MD
    try flipping the plug that plugs into the socket for the car, it seems like import cars tend to have this issue.
  3. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    I agree, the plugs might be reversed even if they fit correctly the first time. The main plugs coming from your car to the ballast.
  4. slowpriusj
    167
    271
    Brunswick, MD
    Yes! I had the same problem, and when I flipped the socket, lights came on! Also trouble shoot to make sure you didn't blow a fuse!
