HID light replacement
Discussion in 'Gen 2 Prius Technical Discussion' started by Eric F, Feb 24, 2008.
  1. Eric F
    Eric F New Member
    Suffolk Va
    First post, I have a 06 prius with HID head lights and after paying $350 at the dealer for a replacement the other one is burning out. Does any one have a part number and a source for a replacement?
    Thanks for the help
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Hi Eric, welcome to PriusChat. Use the Search function (third from the right at the top of the page) to find several posts. Recently someone here bought HID lamps on eBay and installed them himself. As I recall, the price was under $100.
  3. Qlara
    Qlara New Member
    488
    Is HID under warranty?
    Just 2 years for a HID be gone, even for the bulb only, seems a bit too early? Maybe you should find out since you're still under 3/36k for your 06 Prius (unless you're already over 36k in miles).
  4. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    i bought 5500K replacement bulbs on ebay, for 89 bucks. i have an extra OEM bulb.
    The key installing these bulbs isnt to touch the glass.
    the socket type is D2S i believe, or D2R most of the time they make the bulbs to support both D2R and D2S
  5. Eric F
    Eric F New Member
    Suffolk Va
    Please forgive my ignorance but what is d2s and d2r is this a tool or a part?
  6. statultra
    796
    30
    Edison,NJ
    2001 Prius
    D2S and D2R is just the standard, for the bulb.
    its like buying a candle type bulb for your chandelier, its a standard size and connector.
  7. Eric F
    Eric F New Member
    Suffolk Va
    Is there a way to tell which I have? Do I need to pull the old one out and look for a number?
  8. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    EDIT: Deleted misinformation. Sorry for the mistake.
  9. Boo
    5,051
    483
    97
    Flushing, NY
    Your Owner's Manual should say. My 2007 Owner's Manual says that the HID bulb is D4R.
  10. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Careful...there are a lot of inferior fake HID lights out there.
  11. Boo
    5,051
    483
    97
    Flushing, NY
  12. statultra
    796
    30
    Edison,NJ
    2001 Prius
    sorry i thought 06 carried over same bulbs as the 04-05, ebay some d4r bulbs, buy them in original packaging, buy silvania or osram or philips, its much cheaper than dealer
  13. Boo
    5,051
    483
    97
    Flushing, NY
    Yes, from reading other HIDs threads here, I think the 2004-05 HIDs are D2S/D2R and the 2006-08 HIDs are D4R. I understand that they are the same size, etc., but that the D4R is mercury-free.
    In any event, I would have thought that the OP's HIDs were still under warranty.
  14. Eric F
    Eric F New Member
    Suffolk Va
    I am over milage for the factory warrante and the extended does not cover "maintance itmes"
