HID Xenon trouble shoot
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cadenza, May 29, 2019.
  1. Cadenza
    Cadenza Member
    124
    LALA Land
    Hi folks -
    My driver side Headlight is out. First it was intermittent for a few weeks. Now dead for 2 months. How do you diagnose - is the bulb dead or the ballast dead? Thanks!
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Try the bulb first if you're throwing parts at it.
    Skibob likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,331
    6,007
    Columbia, SC
    Since your headlight apparently followed the normal failure process for an HID bulb, why not just purchase 2 new bulbs and install them?
    Why 2??? Because:
    1. standard rule of thumb for HID bulbs is once one goes out, the other will be right behind it
    2. one new one will most likely be significantly brighter than the old one
    3. these bulbs are typically cheaper when bought in pairs
  4. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    And check for moisture in the headlight by the ballast. I have heard that can be a problem.
