Hidden Facts - not in the manual
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by giora, Sep 4, 2015.
  1. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Went to the annual check/test that is required in here. Tester teaches me something i did not know:
    When in READY and Parking - pressing the gas pedal will force ICE to run. Cannot change revs though, it is constant (~2000 RPM? not sure).
    This is true to regular and plug-in Prius, for PiP it does not matter if there are EV miles left or not.
    If this was discussed already - sorry to bother.
    If you have discovered other 'hidden' facts - please share.
    Tracksyde likes this.
  2. Mendel Leisk
    40,582
    With a reg Prius, in Ready but with engine stopped(car warmed up, stopped for a red light for example): you can get the engine to turn on, then off, by raising/lowering the ventilation system's target temperature. The threshold's around 21C IIRC, what's that: 68~70F?
  3. Jan Treur
    Jan Treur Active Member
    240
    168
    Heiloo, Netherlands
    Yes, I also discovered this: after heavy sporting I tried to start driving without putting it in D first.
    51,154
    i'll have to try it, i guess i've never stepped on the gas while in park, in 3 1/2 years.:oops:
  5. fuzzy1
    10,335
    It has been discussed in the past. But apology declined because it remains very poorly known, so the refresher is worthwhile.
  6. bisco
    51,154
    really? on the pip? never heard of it.
  7. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    Does anyone know if the engine will turn off earlier than usual if you drop it into reverse? I know the first and/or second gen Prius did that.
  8. bisco
    51,154
    on the pip?
  9. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
  10. bisco
    51,154
    hmm, another thing i've never tried.
