Hide the key (fob)
Discussion in 'Gen 3 Prius Main Forum' started by learnmedia, Oct 5, 2014.
  1. learnmedia
    learnmedia Junior Member
    17
    Corona, CA
    This past week my wife dropped me off at work and, ignoring the audible warning as well as not noticing the visual warning on the dash, parked my Prius and left the car running all day, from 8:00 AM to 6:00 pm. After sharing the experience with co-workers she then let me know that two of them have a similar experience -- one has done the same and the other has a daughter with a Prius that has done this. ("See. I'm not the only one.")
    I then began to think this might be a fairly common occurrence given the silent operation of the Prius when the ICE is not running. Is it? And is there any potential harm done? My car is running just fine by the way.
  2. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    I would think it just experienced unnecessary wear and tear, but nothing harmful.
    I thought there are various clues to indicate the Prius is still on.
    learnmedia likes this.
  3. situationalawareness
    83
    43
    San Tan Valley, AZ
    The only real issue I could see is how easily the car can walk away with unlocked doors and an engine that's on :)
  4. harper42
    harper42 Member
    226
    Went to a music festival with a friend. Left my car parked in her garage. It was three days later when her husband happened to be in the garage when engine was running. He called our motel and told her. I told him how to shut it off. When I returned to my Prius a few days later I still had nearly a full tank of gas and battery was fine. Her husband (an anti-prius guy) just knew I was going to have a dead battery. I tried to assure him over the phone that all would be well. Sheesh!
  5. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    No harm would be done. You would lower your average fuel economy on that tank and would have wasted perhaps a gallon or two of fuel. In a closed garage it could be dangerous due to the possibility of CO gas being generated. And as posted above the car could be stolen. That's about it.
  6. bisco
    49,488
    when you shut the door with the car on, it beeps at you three times. pretty hard to miss.
  7. bisco
    49,488
    if you make a habit of locking the doors, it won't let you unless you turn it off.
  8. bisco
    49,488
    btw, what does your post have to do with the title?
  9. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    No harm done - the engine would have been off most of that time, just coming on occasionally to maintain the charge on the traction battery.
    A number of us here have kept our cars in Ready mode for many hours while using the Prius as an emergency backup supply during electrical outages. My longest run was 54 hours after Hurricane Sandy, during which the car used only about a gallon of gas.​
  10. learnmedia
    17
    Corona, CA
    Yep. I noted that my wife ignored the audible warning and didn't see the visual dash warning in my original post.
    That I need not allow my wife to drive my Prius. ;)
  11. bisco
    49,488
  12. learnmedia
    17
    Corona, CA
    Thanks everyone for the replies. Sounds like I made much ado about nothing (I was quite annoyed.) I thought that it might mean the traction battery could be damaged. Instead, much of the time was spent with the ICE not running. Another cool thing about the Prius.
    KennyGS and ftl like this.
  13. harper42
    harper42 Member
    226
    And I heard no audible warning because I had decided to leave my key fob in the cup holder in case her husband needed to move the car for any reason. Which prompts another question: Is there any problem with leaving the fob in the car? I park in my garage and do it all the time, for convenience sake. But it seems I recall some discussion on a problem of some sort in doing this. (I have done it for 11 years, in my 2006, 2010, and 2013 Prii.)
  14. macman408
    macman408 Electron Guidance Counselor
    1,179
    366
    If the car is locked and the key is too close to the car, it will use a lot of battery power (mainly in the fob) checking if the key is still close enough to unlock the car. I don't think it keeps this communication up when the car is unlocked, though. But if you notice that your fob battery dies quickly, this could be a reason.
  15. David Beale
    5,963
    1,981
    Edmonton Alberta
    If your wife/husband/significant other leaves the car on like this it's best to just explain to him/her that it's a waste of fuel and possibly dangerous (a kid, for example, could take the car for a joyride) "so please be careful in the future". Family harmony is MORE important than a Prius! ;)
