High beams don't work!!
Discussion in 'Gen 3 Prius Technical Discussion' started by gertsprius, Aug 21, 2018.
  1. gertsprius
    gertsprius Member
    61
    36
    Dubois PA
    2024 Prius
    LE AWD-e
    I was driving home last night and i went to use my high beams and nothing happened no flash of light nothing. I was doing some looking and saw that some people said that it could be that both of the bulbs burnt out at the same time, but in all of those instances they saw the light then it went out. They were working fine the night before. I was just wondering if anyone else had this issue and if there was any other solutions.
    Also, the other day it was raining quite hard and i was using the low speed windshield wipers, i went to turn the high speed on the they stopped completely in the middle of the windshield. it showed signs of trying to move but it just stayed there, when i put them back on low they started again! Any ideas??
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    Are both of those functions on the same "stalk" ?
    Either way, you might have a loose connector along the steering column somewhere.
  3. gertsprius
    gertsprius Member
    61
    36
    Dubois PA
    2024 Prius
    LE AWD-e
    They are two different stocks. That is why i can confused if was on the same stock i would replace it and see if that helped.
  4. sam spade 2
    7,035
    2,798
    2017 Prius c
    It is a STALK.
    And even if they are different, the wires might be in a common connector somewhere down the steering column.
    gertsprius likes this.
  5. ChapmanF
    17,326
    Does the blue high-beam light on the dash come on when you switch to high beams, or no?
    -Chap
    ITBland likes this.
  6. gertsprius
    gertsprius Member
    61
    36
    Dubois PA
    2024 Prius
    LE AWD-e
    The Blue high beam indicator does come on when i flip the switch.
  7. bisco
    51,140
    you might have vermin chewing on the wires.
    how many miles on your 2012?
  8. ChapmanF
    17,326
    Signal therefore is getting from the stalk to the body ECU. Problem is further downstream. Matter of testing and eliminating, possibly with help of the wiring diagram.
    -Chap
  9. padroo
    padroo Senior Member
    2,763
    2,251
    Two burnt out lights?
  10. bisco
    51,140
    and windshield wipers?
  11. ASRDogman
    ASRDogman Senior Member
    7,232
    3,774
    Put a test light on the hi beam wire at the bulb, and LOOK at the bulb and see if it's burned out.
    Turn the lights on and see if the test light lights. If it does, you know the bulbs are burned out.
    If it doesn't light, you know you have some other problem.
  12. ITBland
    ITBland Active Member
    433
    277
    New Orleans, La area, US
    And, don't forget fuses 32 & 33 in the under-hood fuse box.
  13. padroo
    2,763
    2,251
    Check the easy stuff first.
  14. bisco
    51,140
    12v battery?
  15. ChapmanF
    17,326
    Oh for the love of Pete.
    Raytheeagle likes this.
  16. gertsprius
    gertsprius Member
    61
    36
    Dubois PA
    2024 Prius
    LE AWD-e
    I have 80K, I got some new light bulbs and changed the bulbs, turns out they both just blew at the same time! I just think that it is weird that they both went out at the same time!
  17. gertsprius
    gertsprius Member
    61
    36
    Dubois PA
    2024 Prius
    LE AWD-e
    I still don't understand the wiper problem i am going to have the dealership look at it. Since i work for the local Toyota Dealer.
  18. padroo
    2,763
    2,251
    Usually one is already out and you don't catch it and then the other one goes out.
    You haven' t jumped the car recently have you?
    Where I used to work they would jump company trucks and use their 24 volt jump pack and if the headlight switch was on it would take both headlights out.
  19. gertsprius
    gertsprius Member
    61
    36
    Dubois PA
    2024 Prius
    LE AWD-e
    No I haven't jumped it ever. I don't even know how. i remember the dealership telling how but i don't remember any of what they said!:ROFLMAO::ROFLMAO:
