high efficiency refrigerators
Discussion in 'Environmental Discussion' started by tomdeimos, May 8, 2006.
  1. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    I've just ordered a new refrigerator, as a start on updating most of my appliances to more energy efficient models.
    It is a Kenmore model 74212. 417 KWH per year. This was the lowest energy unit I could find with the cu ft I needed in a combo fridge-freezer. I considered all fridge units too as my freezer is next on my list to upgrade.
    Learned a few things searching on the web while I was looking.
    1 Whirlpool made an energy efficient refrigerator a few years ago and dropped it because nobody would pay the extra $40 it cost. Bet it would sell better today. So I missed out on the chance to get it.
    2 Sunfrost makes the top efficiency model fridge I can locate. 204 kwh per year. Available in dc models too for battery operation. Unfortunately their design doesn't seem to work as well for freezers and their combo units are a bit small for me.
    3 The second lowest energy large fridge only I could locate was a WCWoods 18 cu ft at 335 kwh per year.
    Sears and whirlpool have units that should be great but aren't. You can run them in a garage to save energy in winter! But they are energy hogs, so people wanting them to save energy will probably lose what they gain.
    4 Refrigerators with freezers are still mostly all made wrong. They should have separate isolated chambers with separate evaporators as a minimum but these seem to be available only in very high end large units. Sunfrost is an exception on the size, but the size mix is wrong for my needs. Units like this include the GE Arcticas but only in the large side by side styles.
    5 Energy efficient combos only come in top freezer models, except the Sunfrost where you can choose top or bottom models. This should not be, but is a result probably of the defects in item 4.
    6 The energy ratings don't tell you who makes good designed units and who is cheating by undersizing the conmpressors so they won't maintain temperatures on a hot day! This info seems to be totally unavailable.
    So it would be nice to know what they did do for energy savings. The best units should have brushless dc variable speed compressors. The worst would be single speed induction motors. In between there could be 2 or 3 speed motors. This info also I could not locate.
    Another way for energy savings would be thick insulation. Sunfrost does this. Nobody else even matches the thickness of my old fridge (which was still new enough to have foam insulation.). They all seem to have gone back to thin insulation.
    So with next to zero information I had to buy by brand name. Another shaky idea since nobody makes their own products any more. I did learn LG makes most drawer type bottom freezer units. (You only see this kind of info when there's a recall!) And Whirlpool clearly makes the Kenmore I bought, but I have no idea whether someone else really makes the unit for Whirlpool.
    Nothing to do with refrigerators but from reading recall info I learned the Maytag repairman is getting busy, due to Maytag not even making their washing machines nowadays! I read they were switching from LG to Samsung for their high end machines, after having problems.
    7 So I turn to Consumer reports and they have only vague ratings on mostly obsolete models. They seem to care more about the count of butter keepers in the doors! They won't tell me what the actual temperatures do in various parts of the fridge and freezer compartments when the ambient goes over 100 degrees or below 50 degrees as it does in my house! Years ago they did cover this kind of stuff much better!
    I did manage to locate a Whirlpool warning not to let the room go below 55 degrees. Sorry Whirlpool I set my thermost at 50 degrees when I am not home and I will have to maybe modify your unit to handle this!
    So overall I am pretty frustrated and just crossing my fingers the thing works. My old Amana still works great but being over 25 years old I am sure it uses excessive energy.
    My goal is to cut my electric bill by at least 50%. It is running now in the $200 to 300 range. Rates here for me are roughly 15 cents and 25 cents a kwh winter, and 15 cents or 40 cents in summer. Depending on time of day.
    Next on my list are:
    1 Freezer (WC Woods seems to be the only choice here. Esp with Fridgidaire changing owners all the time.) Manual defrost chest if I can fit it somewhere. My current unit is an upright frost free, and I feel very wasteful using it since getting a Prius!)
    2 Washer (waiting for more on the new Equator combo top loader with horizontal drum.)
    3 furnace blower motor (must convert this to dc brushless. My blower motor is 1/2 hp.)
    4 sump pump motor (I already know what to get here, just very hard to find: Rule! At least if they still make it. It is dc brushless design like the marine bilge units, but runs on 110 AC)
  2. saechaka
    saechaka Member
    225
    <div class='quotetop'>QUOTE(tomdeimos @ May 8 2006, 11:30 AM) [snapback]251497[/snapback]</div>
    sure wish priuschat had a stickied thread listing what energy efficient appliances and household items are best to get to help lower energy costs and the environment of course.
  3. priusblue
    priusblue New Member
    152
    <div class='quotetop'>QUOTE(tomdeimos @ May 8 2006, 12:30 PM) [snapback]251497[/snapback]</div>
    Great idea with the new fridge - if you're looking to cut your electricity costs, one of the cheapest and easiest ways is to replace your regular lightbulbs w/ compact fluorescent, if you haven't done so already. These work great and last longer than regular bulb, use about 1/4 the electricity, and don't produce as much heat - saving you on A/C also. You can find them at Lowe's and Home depot, but if you need dimmable or specialty ones, here is a website: http://www.energyfederation.org/consumer/default.php There are other websites out there too.
    Also, someone else on here pointed me to this website, which helps you prioritize your efficiency improvements to get the biggest bang for the buck:
    http://www.rmi.org/sitepages/pid195.php
    We got our ducts sealed with mastic and and got our system checked out, and that made a huge difference and helped with comfort.
    Also, see my post on the Kill-A-Watt:
    http://priuschat.com/index.php?showtopic=18148&hl=
    You'll be amazed how much electricity you leak.
    It helped us cut about 100 kWh off our bill, just by putting some things on timers, using smart strips (which cut off the power to accessories when you turn off a device), and putting the computer on hibernate (4W vs. 60-80 W) when we weren't using it.
    Doing just the things listed above, we've been able to go from about 1000 kWh/month (all electric 1600 sq. ft. house) to 770 kWh/month. Hopefully with some more insulating/sealing work, some tubular skylights, and a solar hot water heater, we can cut even more off.
    Good luck!
  4. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Thanks for the fridge rundown. I know that I'm going to be in the market soon. I tend to do tons of research and know everything going into the purchase and when it's over I rapidly forget it all.
    Sounds like you are the same way - if only in the research department.
    Thanks for the tips.
  5. ohgreys
    ohgreys New Member
    123
    We have an energy efficient Whirlpool fridge. Not sure of the model number but I'm guessing it was the one that was discontinued. I can remember thinking that it didn't seem to be too much of a premium to pay for an energy efficient model.
  6. tomdeimos
    995
    Lexington, MA
    <div class='quotetop'>QUOTE(TonyPSchaefer @ May 8 2006, 01:16 PM) [snapback]251542[/snapback]</div>
    I should mention that I read another boost in efficiencies is due soon, now that I have ordered mine! I think there will be more with variable speed motors and some more efficient refrigerants. I read something like another 25% improvement is possible.
    If you are not in a rush, you may want to google LG and their new linear motors which look a lot like what I have in my Prius car fridge. It is an Engel, cooler chest that works as a freezer if you wish too, and draws about 2 amps from the car battery.
  7. tomdeimos
    995
    Lexington, MA
    <div class='quotetop'>QUOTE(priusblue @ May 8 2006, 01:04 PM) [snapback]251525[/snapback]</div>
    Thanks for the tips. I have indeed switched to mostly fluorescent lights, except for a Sodium light for my outside light. And I have used some of the Phillips ones that dim.
    I am trying to take this project in order of the improvement I can get. I lost my original EPA sticker info, but I estimate my old fridge and freezer purchased back in the 70's use a lot. Probably over 2000 kwh per year. Plus with my time of day rate, they are the main things I can't turn off for the peak rate times (8 am to 9 pm winter and 9 am to 6 pm in summer, monday to friday.)
    I have ordered a watts up pro to start measuring stuff. I want to see the start up surges too, another thing nobody bothers to specify so I can see what will work on my Prius with inverter, when the power goes off!
  8. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(priusblue @ May 8 2006, 10:04 AM) [snapback]251525[/snapback]</div>
    Scariest to me is that I do, or have installed every tip and product listed on that page... and of course I've even gone far beyond what is listed in some instances. And then the power company comes out and says "if you can save 20% off your energy as compared to last year, we'll give you a big cash bonus!" Crap... what up those of us who are already doing every damn thing they can - the ones who were part of the solution BEFORE it became a crisis?
    And then there's the fact that I save energy by charging my electric car at home.... The "big" picture is often lost in the details.
  9. jmccord
    jmccord New Member
    199
    San Diego, CA, Earth
    Typical. The more you waste, the more your rewarded for baby-steps toward improvement. <_<
  10. Jonnycat26
    Jonnycat26 New Member
    1,748
    New Brunswick, NJ
    I have a high efficiency Kenmore as well, and most high end Kenmore units are actually made by Whirlpool, with the exception of some dishwashers, which are made by GE.
    FYI, you should never set your temperature as low as 50 degrees. Most houses do not heat evenly, and your basement will probably be colder than the area where the thermostat is (usually on the first floor). At 50 degrees and below, you run some risks of damaging your pipes.
  11. jimnjo
    jimnjo Member
    117
    2015 Prius c
    For the freezer look at Crosley, too. Check it out at Backwoods Solar, where they ship as part of the selling price (under $600 for a full size freezer). www.backwoodssolar.com, I think.
  12. tomdeimos
    995
    Lexington, MA
    <div class='quotetop'>QUOTE(jimnjo @ May 12 2006, 06:44 AM) [snapback]254007[/snapback]</div>
    The Crosley freezers are made by Woods, and they seem about the best I can find. I'm looking at a 10 cu ft chest, manual defrost rated 282 kwh/year. Crosley seems to have same ratings on theirs. For checking who makes what I found this web site:
    http://www.appliance411.com/purchase/make.shtml
    The other key site is http://energystar.gov where you can see a list of every energy star rated freezer or refrigerator.
    Just an update: I got my watts up meter and it seems very useful. Looks like my old 70's era Kenmore freezer is still competitive by todays standards but my Amana refrigerator is not.
    Looks like I can save 75% electricity on running the new fridge, and 50% on the freezer. But the freezer will only save because of a switch in type to a manual defrost chest. Fridge savings are with same type and even slightly larger size.
    Guess they don't sell enough freezers to invest in making them a lot better!
  13. Godiva
    Godiva AmeriKan Citizen
    10,339
    A few years ago I replaced my refrigerator with a GE profile. I'm not sure what the energy rating was, but I bought it because it has the freezer on the bottom. More efficient as you open the refrigerator compartment more than the freezer so it's at eye height...less stooping.
  14. tomdeimos
    995
    Lexington, MA
    I agree bottom freezers are nicer. I had one once. But for min energy use the top freezers all
    seem to do better in the energy specs. I see no technical reason for this. But that is the only reason I ordered a top freezer.
    But if it is too low for me I plan to build a platform and raise it up a bit off the floor. Kind of the basic idea Sunfrost suggests on their web site! Then I should be OK with it.
  15. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    Sunfrost makes the most efficient refridgedeezers. Largest size: 19 cu ft. Weakest design feature: door gaskets.
    We have a large Sunfrost refridgedeezer (refrig on top, freezer on bottom) and a Whirlpool SERP side-by-side, with ice maker in the door. The Sunfrost has thick walls and doors. Whirlpool walls and doors are thin by comparison.
  16. tomdeimos
    995
    Lexington, MA
    Got my new 10 cu ft freezer home fully inside the Prius. New Kenmore was delivered by Sears.
    I have now measured everything with the watts up pro and my old equipment (from around 1978 ) was not quite as bad as I expected. But my net electricity cost saving should be 46% for the new freezer and around 71% for the new refrigerator.
    I don't remember the actual energy ratings of the old units, but my meter was measuring everything under similar conditions. New units specs are 417 kwh for the refrigerator and 282 kwh per year for the freezer.
    Freezer looks like it has a good 3 inches of insulation. It also has little waste space not needing coil and fin space. It uses the case to dissipate the heat. This design eliminates all fans too. At regular room temp it measures a 40% duty cycle.
    Very impressed at how quiet both uinits are compared to my old units. Takes some getting used to on the refrigerator hearing the fan going without the compressor a lot of the time.
    The refrigerator has thin insulation, so they are getting the low energy use some other way, I assume with an extra good compressor. Somehow it compares quite well to the Sunfrost RF19 (8-8 cu ft at 359 kwh vs 15.2-6.5 cu ft at 417 kwh) when you adjust for the capacity differences. They make do with one fan for the evaporator with a variable damper to control the air flow proportions. Condenser fan seems to be variable speed. I've seen wattages of over 120 watts and down to 70 watts with 2.5 watts when just the evaporator fan is going.
    Both the Woods and the Kenmore Elite use Embraco compressors. I gather most Whirlpool equipment does.
    Woods makes freezers for Whirlpool and near as I can tell they are virtually the same except for trim items, since Whirlpool has Woods make all their frezers according to their web site.
    Looks like the Prius will be able to run the freezer no problem. About 15 amps for start up as a short spike followed by 8 amps for the rest of the motor spin up. My inverter should handle this.
    The refrigerator has more of a single start up spike at 23 amperes and this will be harder to get running.
    Once going both together should draw under 2 ampers, so should be easy for the Prius to power during power outages.
    Interesting that nameplate amps are the opposite of what I measure with freezer at 6 amps and refrigerator at 3 amps.
    Freezer is a manual defrost chest, the Woods 10 cu ft C1011W3
    Refrigerator is a top freezer Sears Kenmore Elite 21.7 cu ft 74212
    My Prius powers a 1500 watt Tripplite inverter, for my back up power system.
  17. SSimon
    SSimon Active Member
    1,426
    N/W of Chicago
    <div class='quotetop'>QUOTE(tomdeimos @ May 8 2006, 02:01 PM) [snapback]251610[/snapback]</div>
    When using flourescent lights, please note that these should be recycled. They contain mercury. Usually they have an 800 number on the packaging. If not, Sierra Club has a website where you can key in your zip. It lists recycling centers in your area for all types of hazardous waste (including your used car oil). Flourescent bulbs appear under the miscellaneous catagory.
    http://zoomer.sierraclub.org/#
  18. tomdeimos
    995
    Lexington, MA
    One more advantage of new energy saving appliances:
    My 1 kw Prius inverter can handle much more.
    It used to run my refrigerator but could not start the freezer compressor even by itself.
    Last night the power went out in a thunderstorm and stayed out. After waiting 5 hours, I went out and hooked up the Prius to my new freezer and refrigerator. It ran both happily and I had power for something else too!
    Power came back this morning after being out for over 10 hours.
  19. vkykam
    vkykam New Member
    27
    I'm using a LG WM3677HW combo washer/dryer. We thought about the Equator, but decided on the LG because it offered a 3.7cuft drum.
    The best part is that it runs on a 120V 15A (standard) plug, not the 240V 30A plugs, it's one unit (set time and forget, no washer->dryer run), and there's no exhaust pipe (no heat loss in the winter).
    The downside is that sometimes the clothes don't come out 100% dry, particularly if laundry density isn't sorted, such as mixing t-shirts with cotton towels, and that the wash/dry cycle takes 3.5-4hrs. But it's still far more efficient than the traditional washer/dryer separate units.
    Been using it for almost 6 months, and no regrets.
  20. Godiva
    10,339
    I am really glad I have a recycling washer. I bought it about...15 years ago? It's a Whirlpool Watersaver. It has the capacity to draw the water back in from my sink and reuse it for another load. This may sound bad, but at the time I bought it I checked and Consumer Reports said that there was no loss of cleanliness in the loads they tested. It may not save on my energy bill, but it helps with the water bill.
    Unfortunately, I don't think they make that model anymore. Probably because people couldn't accept the recycled water.
