High mileage C purchase?
Discussion in 'Prius c Main Forum' started by JoelB, Jan 15, 2020.
  1. JoelB
    JoelB Junior Member
    There is a 2013 prius C two in my area with 158k miles for $4995 that I thought was interesting. Curious if anyone thinks this is a purchase worth thinking about. Is pricing decent? Maybe mileage is at a point where i should worry about reliability. Clean title, unlikely any service history is available.
    I'd like to have one of these little C's as a second car as i really like them. But i can't spend too much on a second vehicle.
  2. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    Going by the nada book value, it seems to be a pretty good price for my zip code.
    The Prius "c" is a pretty reliable car
    As for the hybrid battery, if it is the original, then the warranty is is long gone.
    That would be about the only questionable item on the car, after a good looksee from
    you if capable, or from experienced hybrid shop.
    The "c" HV batteries are smaller than standard Prius batteries, so they tend to get a bit more use/abuse.
    As for using it as a second car?
    How often would it be driven? and how far?
    Would it sit for long periods without use?
    Only asking, since Prius HV batteries like more usage than sitting.
    Not much options to replace the HV other than used/reman (which not the best decision) or
    new from dealer, which will be a price shocker.
    You could look into maintaining it, with a Prolong charger from
    Prolong Battery Systems. Extending the life of your hybrid. — Hybrid Automotive
    Just my opinion, I think for $5k it is a good deal. Perhaps haggle to $4k and it is even better :cool:
    Read up on the Prolong charger and other topics regarding maintenance such as,
    brakes, spark plugs, transaxle fluid, shocks/struts
    as these items may or may not be costly, if you DIY or if you need to see a shop
    or even worse have to go to a Toyota dealer.
    But the history may or may not prove that any of these were done, or done correctly, with proper maintenance.
    Good luck! post other questions too!
    bisco and Lukey51 like this.
  3. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    They actually last longer because of its lower voltage. 144v for the C vs 201.6v in the normal Prius. There was a thread somewhere about this.
    Lukey51 and dig4dirt like this.
  4. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    Very good to know!
  5. JoelB
    JoelB Junior Member
    Thanks for that reply, definitely some good info. I looked at it again and there is a Carfax linked. It’s a 1 owner that had its 5k, 10k, 15k, 20k and 25k services done at the dealer right on time. After that it just shows registration renewals so I’d assume it was serviced somewhere that doesn’t report to Carfax.
    dig4dirt likes this.
  6. Leadfoot J. McCoalroller
    8,149
    7,654
    Pennsylvania
    2018 Prius c
    I believe mileage is secondary to age with these. Sounds like a decent one. Good luck!
  7. bisco
    52,404
    how many miles a year do you think you'll put on her?
  8. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Huh? first I've heard that.... I've read more than a few threads here where it's mentioned these things are dying off about a year or two before the warranty expires. No big complaints there, since they get replaced.
  9. Leadfoot J. McCoalroller
    8,149
    7,654
    Pennsylvania
    2018 Prius c
    Yeah I'm similarly doubtful of @iceman13 's claim re: lower voltage for longer life. People want long warranties on traction batteries, right? So if Toyota reasonably could offer a long warranty on the c battery they would. The only reason not to do so is because they'd spend too much money giving away batteries.
    So why is the c battery warranty two years shorter than all the others?
    I don't have access to Toyota's data, but I've satisfied myself with the idea that the reduced warranty is because they don't expect this battery to last as long as the bigger ones.
    dubit likes this.
  10. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    Maybe I misread some info about the lower voltage related battery life but certainly it doesn’t have anything to do with the warranty Toyota offers. Toyota only upgraded the warranty on 2020 model year and onwards hybrids. I believe the last model year for the C was 2019. It’s only a marketing strategy to catch up with increasing competition and compelling new buyers. I’m 100% sure it has nothing to do with them not having enough confidence on the C’s traction battery and losing money.
  11. Reno411
    Reno411 Junior Member
    17
    Lehigh Valley, PA
    I have 308,000 miles on my 2013 prius c. I can say go ahead and buy it and tomorrow the engine blows on you. Every car is different. Every driver drives their car differently. If you like the car and can afford to spend the money, than buy it. If not, than don't buy it.
