high mileage synthetic or just synthetic?
Discussion in 'Gen 2 Prius Main Forum' started by ericspoor, Aug 8, 2018.
  1. ericspoor
    ericspoor Member
    76
    37
    austin
    should i use high mileage synth. on my 242,000mi prius or just synthetic? doesn't seem to burn much oil
  2. Mendel Leisk
    41,511
    Oil labelled "high mileage" contains additives that swell rubber, basically attempting to tighten up valve seals. I would not use it unless I had a serious (near-terminal) oil consumption. Also, once you start with it, you pretty much have to stick with it. Going back to regular (non high mileage) oil, the valve seals may shrink back, with a vengeance.
    I can recall looking at a bottle of this stuff, decades back, wondering the same thing. They really should clarify on the bottle, what it's for, what it's doing.
    PriusCamper likes this.
  3. JC91006
    16,769
    8,567
    If it's not burning oil, stick with what you've been using. Don't change anything
    edthefox5 and Raytheeagle like this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    THIS.
    Except maybe what do you consider as "not using too much oil" ??
    If you are up to a quart in 3000 miles or less, it might be time to switch......and go up a step in weight too unless you live where it is REALLY cold.
  5. ericspoor
    ericspoor Member
    76
    37
    austin
    so what would yall do if ive been running high mileage synthetic for the past 1000 miles? change it back or just use high mileage from now on, since i already have it in my engine?
  6. sam spade 2
    7,035
    2,803
    2017 Prius c
    I think that's already been answered.
    Stick with it.
    What IS your oil consumption like ?
    And what weight of oil are you using ??
  7. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Stick with the high mileage ;).
    The toothpaste is out of the tube, so no going back now(y).
  8. ericspoor
    ericspoor Member
    76
    37
    austin
    sam - i haven't had the car long enough to notice any oil burning (no burning the past 1000 miles anyway, the period of time ive owned the car). im using 5w 30
  9. Mendel Leisk
    41,511
    You could try an oil change with regular oil, see what happens. I don't believe you've mentioned your oil consumption rate?
  10. ericspoor
    ericspoor Member
    76
    37
    austin
    only owned the car for those 1000 miles (changed oil immediately after purchase). so far haven't lost anything on the dipstick
  11. sam spade 2
    7,035
    2,803
    2017 Prius c
    A 13 year old car with over 200K miles......and isn't using ANY oil !!! :)
    WOW it sounds like you got a REALLY good deal.
    Please keep us posted.
    Just for the record, oil usage is the ONLY reason for the existence of "high mileage" oil.
    It sounds like you really didn't need it......but that might be WHY it doesn't appear to be using any too.
    Stick with it. No going back now.
  12. frodoz737
    frodoz737 Top Wrench
    4,702
    2,500
    33
    13 YO Prius with 242,000 miles? Just change the oil/filter every 5K with what's been used before, check every fill-up and top off with same as required. So called "high mileage" oil won't make any difference.
  13. sam spade 2
    7,035
    2,803
    2017 Prius c
    And you know that ...how, exactly ??
    It won't fix everything that causes oil loss but it does a surprisingly good job in a lot of cases.......as a temporary "fix".
  14. frodoz737
    4,702
    2,500
    33
    Oh I don't know...maybe because I've been turning a wrench professionally for more than 40 years might have something to do with it. ;)
  15. sam spade 2
    7,035
    2,803
    2017 Prius c
    That does not mean that every ASSumption you have arrived at over 40 years is really valid.
    I personally have seen it make a distinct difference in more than one engine.
  16. frodoz737
    4,702
    2,500
    33
    WOW! Name calling on an oil thread? :ROFLMAO: You have a nice day sam spade 2.
    Anyways...ericspoor you already know this used vehicle has a limited time left on the clock. Follow my advice and you will be fine until then. ;)
  17. ericspoor
    ericspoor Member
    76
    37
    austin
    based on the service records it had bulk oil for 75% of its life and the last 25% has been synthetic, so i guess ill stick with synthetic high mileage like people are suggesting
  18. Mendel Leisk
    41,511
    While bulk oil often is just regular, the connection is not hard-and-fast. At my local dealership I purchase bulk Toyota 5W20 (for a Pilot) that is regular oil, and bulk Toyota 0W20 which is synthetic. Also, there's nothing wrong with regular oil, in particular if you abide by the oil change intervals, never let the level drop low.
    I've been using bulk Toyota 0W20 synthetic for DIY oil changes on our (2010) Prius for maybe 3 years now, both because it's cheaper and to avoid contributing oil-fouled empties to the recycle stream (or landfill?).
    That's one downside to DIY, the prevalence of small containers fouled by various hydrocarbons. Another example: my daughter is redoing a deck, using large vats of some sort of roofing tar. The "empties" are an ecological disaster; it'd be much better if there was some service with tar tankers (like a redi-mix concrete truck).
    #18 Mendel Leisk, Aug 10, 2018
  19. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    To the op your burning oil just don't know how much. Check the oil every few days first thing in the am as all the oil will have drained from the VVT section by then and its the most accurate measurement. Check it every few days. The G2 motor takes about 3.5 quarts of oil with new filter. Check it next morning after an oil change. Keep it at the full line.
    Its a rare 250K G2 motor that does not eat oil. I would just use cheap dino oil 5-30 and take it easy on the car.Buy 5 quart jug at walmart.
    Good luck.
    frodoz737 likes this.
  20. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    You are about 400-4000 miles early for confirming no oil burning. If it happens (and usually does) then wait until 1500 or 2000 miles driven and recheck.
    I'd bet that you cannot go 5000 miles without dropping below min on dipstick.
    Walmart is THE ONLY PLACE TO BUY OIL!!!! (Also free 2 day shipping and no $130 annual "prime" membership nonsense).
    $25.47 at Walmart (Mobil One 5W30 Extended Performance Full Synthetic)
    Mobil 1 5W-30 Extended Performance Full Synthetic Motor Oil, 5 qt. - Walmart.com
    Or you can pay $42.99 at O'Reillys.
    $9.17 at Walmart for the extended performance oil filter
    Or you can pay $14.99 at O'Reilleys.
    Walmart grand total: $34.64
    O'Reilleys grand total: $57.98
    I bring my own oil to oil change shop and they change it for $15 (most shops are $20).
