High pitch beep noise from speakers that will not stop
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by totalimpact, Aug 8, 2018.
  1. totalimpact
    totalimpact Junior Member
    san diego
    2014 Prius v wagon
    I have a 2007, 175k, replaced the 12v battery in January, and reconditioned the traction battery with 1 new module. It consistently gets 46-47mpg, running great.
    Today my wife calls and I could hear it on the phone, as soon as she presses Start, there is a loud wine over the speakers, it does not stop, even as she drives it will not stop the loud beep/wine... There are no warning lights on, no ABS flashing, no triangle, no codes, no open doors. She left the house this morning and drove ~20 miles without issue, couple stops, then she gets in and it starts this beeping. The MFD shows the traction bat at 50%, it appears to drive fine.
    I had her check the maint menu on the MFD, the 12v bat shows 11.9 volts, but this is probably a little low because we have been turning it on/off a bunch trying to figure this out.
    Having her look for codes now, but no CEL was shown.
    I have seen a few other threads about this, only useful info was to replace the aux battery, but it was new 8 months ago, I dont see how it could be shot already. If anyone else has seen this issue please let me know.
  2. totalimpact
    san diego
    2014 Prius v wagon
    Codes pulled
    01-db-190-df-f
    01-db-190-55-9
    01-db-110-F3-3
    -190 are Head unit related (no idea)
    -110 is MFD (no idea either)
    Is the MFD bad?
  3. totalimpact
    san diego
    2014 Prius v wagon
    I got home a bit late, checked voltage on my multimeter, aux bat shows 12.6v, plenty for me. I checked codes on Torque, no stored codes, but I guess it cant check more advanced bus codes.
    I am hoping for some pointers to narrow it down to the MFD or the stereo, it definitely comes out of all the speakers, and while stereo can still play in all modes, wine still comes out.
    I shot a short video of the it if anyone wants to hear how terrible it is:
    49,387
    how long had the car been off when you checked the voltage?
  5. totalimpact
    san diego
    2014 Prius v wagon
    Car had been off for 2-3 hours....
    Anyways a trip to pick-a-part, and a new stereo solved it....
    Thank God it wasnt the MFD... of the 8 prius in the yard, 3 had arrived that SAME day - NONE had MFDs.
    Mendel Leisk, bisco and Patrick Wong like this.
  6. Patrick Wong
    18,200
    6,472
    Did you replace the stereo head unit in the dashboard; or the JBL amplifier under the seat?
    valde3 likes this.
  7. totalimpact
    san diego
    2014 Prius v wagon
    just the head unit, not the JBL, so no amp, no changer.
  8. rabbit1985
    rabbit1985 Junior Member
    Tucson Arizona
    Any updates on what the fix was?
  9. dolj
    dolj Senior Member
    7,631
    3,849
    Wellington, New Zealand
    What kind of an update are you after? The fix is stated in posts 5, 6, and 7.
