High Pitch Whirring Sound
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DenToyPri05, Mar 1, 2015.
  1. DenToyPri05
    DenToyPri05 Junior Member
    118
    24
    Denver, Co
    It's been cold, but I've been driving. When I park and power down, I'm hearing a high-pitch sound...like a fàn...it lasts about 10 seconds.
    What is my car doing?
  2. Patrick Wong
    18,200
    6,479
    That sound is produced by the engine coolant heat recovery system pump, which operates upon start up and shut down. It is normal for the pump to operate at those times.
    DenToyPri05 likes this.
  3. Britprius
    Britprius Senior Member
    5,194
    1,917
    Herefordshire England
    This is the sound of the pump returning hot coolant to the thermos tank. Some pumps get noisy in the cold but it does not affect the performance. If it fails a DTC code and warning light will appear. The car can still be safely be driven in this condition.
    John (Britprius)
    DenToyPri05 and valde3 like this.
  4. valde3
    valde3 Senior Member
    2,002
    745
    Finland
  5. bisco
    49,842
  6. DenToyPri05
    118
    24
    Denver, Co
    because i'm in a racecar...vroom vroom!!! :)
    you know that on-ramp signal to enter highways? depending on whom I am paired with, I'll either "race" or take it easy. when i'm next to an audi or bmw, i wear my grandma hat; when i'm next to any kind of suv, i whiz ahead...that's turbo. lol
  7. davidls
    davidls Junior Member
    33
    Ipswich Queensland
    Hi Patrick,
    I have a 2008 model, in Australia, and this car does not have a thermos. However- I get this whirring sound also. Sometimes I go into the garage and if I open a door, it may start. I wondered if it might have something to do with the key in my pocket, but this is not a smart key. What do you think this noise is? Is it something to do with brake line pressure?
    Thanks,
    David
  8. Patrick Wong
    18,200
    6,479
    Hi David,
    You are hearing the brake actuator motor running. If the driver's door is opened while the car is IG-OFF, the body ECU communicates this info to the skid control ECU which powers up the brake actuator to build up pressure in the hydraulic system, thus getting the car ready to be driven.
    Another possible noise that you may hear the Prius make after it has been parked for a few hours is that the fuel tank will be pressurized to check for leaks. You may hear a pump running for a brief interval when this test is executing.
    Data Daedalus likes this.
  9. Britprius
    5,194
    1,917
    Again Patrick the Australian Prius does not have a pump to pressurize it to check for leaks. It is only the North American continent Prius that uses the bladder system with the leak detection.
    John (Britprius)
  10. davidls
    33
    Ipswich Queensland
    Ah- thanks Patrick. You're a gem!
    Thanks John for the clarification. Aren't we lucky here down under:)
    #10 davidls, Mar 6, 2015
  11. Britprius
    5,194
    1,917
    You get the same deal as us in the UK/EU.
    John (Britprius)
