High pitched beep at start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by siouxscout, Sep 28, 2014.
  1. siouxscout
    siouxscout New Member
    knoxville, tn
    Hello everyone I've searched for this issue and haven't found a thing.
    There is a high pitched beep when I start my 2009 prius(with 101k miles), but there are no warning lights on the dash. So im not sure what could be causing it. I did notice the aux battery is only showing 10v on the diagnostic screen. So ill replace that soon. But that shouldnt cause the beep right? Also i say its high pitched because it is compared to the seat belt beep for example. But so far no other i
  2. Patrick Wong
    18,200
    6,472
    Start by replacing the 12V battery. When voltage is abnormally low, some weird behavior can result.
    49,392
    and do it before you get stranded somewhere. welcome to priuschat!(y)
  4. dolj
    dolj Senior Member
    7,631
    3,849
    Wellington, New Zealand
    Yes, change the battery and it will probably resolve the beeping issue.
    I have had the car beep as you describe due to low 12 V battery issues, so I'd say yes definitely it can cause the beep. I found the beep coincides with the red triangle flashing, which I have interpreted to mean low (12V) voltage detected.
    #4 dolj, Sep 28, 2014
  5. dirtpimp
    dirtpimp Junior Member
    SoCal
    I get this same beep only when I shut off the car. Went away when I changed the battery on my remote. Same year car with 112k miles.
