High Pitched Whistle and otehr new sound
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by spidey, Jun 24, 2009.
  1. spidey
    spidey Junior Member
    81
    central north carolina
    After shutting down the car I am noticing a high pitched whistle that seems to continue for 5 minutes or more. I had noticed it once before but seems to be more frequent.
    I have also started to hear a sound that is similar to a break squeak however noticing it while driving and not breaking and not as loud as a break squeak. I still haven't been isolate if its only drivers side, front or back just a new sound to debug.
    Any Ideas???
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    This one may be that the holes under the side rear view mirrors got unplugged. Easy to check. Good luck! :)
  3. spidey
    81
    I found the holes and both look like a plug was never in them. If this was the cause I would think I would hear it all the time and not finding this to be a constant sound
  4. Bob_Stan
    Bob_Stan New Member
    70
    Central New York
    Missing plugs only cause a sound when moving.
  5. geeky teacher
    geeky teacher New Member
    393
    West Suburban Chicago
    Missing plugs cause the high pitched sound when moving and it increases in volume with an increase in speed. Put a piece of scotch tape over the holes.
    Brake noise without braking? Does it happen while making a tight turn? I can't help you with this one.
    We once had a rock get stuck up in the suspension in another car. That made a horrible sound.
  6. spidey
    81
    Ok there are two sounds, The high pitched whistle is when car has been shut off and occurs for almost 5 mins.
    The second is the "squeech" when moving but not consistent. I am starting to think it sounds a bit like a sprocket that needs a little grease but havent had to do that to a car since the 1970's
  7. richard schumacher
    7,663
    1,038
    United States
    Whistle when OFF: Wth?
    Squeech when driving: possible suspension problem.
    See a dealer. The latter item is potentially dangerous, and the former is a mystery.
