High Rev motor at complete stop.
Discussion in 'Gen 2 Prius Technical Discussion' started by 2005dahl, Aug 15, 2012.
  1. 2005dahl
    2005dahl Junior Member
    texas
    Hi everyone.
    I have about 05 with 110000 miles on car and have started to notice that the motor sounds like it is reving up when I come to a complete stop or even hyper miling. I have plenty of juice in battery Not Gree and Not Orange. While at a complete stop if I switch from Park/drive/Neutral some times it will then shut off.
    Any thoughts??
    Thanks
    David.
  2. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Usually that should only happen when the traction battery is fully charged (at the full 8 green bars). It cranks over the engine (without fuel injection) just to take some excess charge off the battery. I've never seen it happen with anything less than the full 8 green bars. That sounds very strange.
  3. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    Check the throttle body is not dirty and that the butterfly returns all the way. Do a search on Throttle body cleaning this will tell you everything you need to know.
  4. mbooth62
    mbooth62 Junior Member
    28
    San Jose. CA
    I've only see in happen in B mode ....not Drive
  5. Britprius
    5,194
    1,914
    It also happens in drive when the HV battery is full.
  6. 2005dahl
    texas
    Going to stop by the Toyota Dealer on the way home today and see if they have seen it. Will post results.
    Thanks...
  7. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Yep. And it doesn't normally happen in "B" when the car is stopped.
