High RPM Danger in Cruise Control
Discussion in 'Prius v Main Forum' started by TomNat, Jun 2, 2016.
  1. TomNat
    TomNat Junior Member
    31
    Colorado Springs, CO
    2015 Prius v wagon
    We have about 11K miles on our 2015 v model 5, and have just returned to Colorado from 6 months in FL. On the way down to FL last Nov, we did not use cruise control on going up Raton Pass >8Kft., but on our return we did use cruise control set at the 65 mph speed limit. The engine went to very high RPM to maintain 65 mph. I lowered the cruise set point to 60 mph to reduce the RPM some near the top of the pass.
    Will the Prius v automatically protect itself/disengage cruise control or give a warning if RPM get too high in cruise control? Thanks!
  2. ETC(SS)
    6,589
    Short Answer:
    Be not Afraid.
    Even if you WANTED to, it's impossible for you to over-tach a Prius.
    Ever.
    Do you want to know why Priuses don't have a tachometer?
    Right.
    Because they don't need one.
    For many cars, I would say that the buzz-kill people who designed the car wanted to remove ANYTHING that would make the driver more connected with the vehicle, and this is true enough in some cases for the Prius.
    Examples: Steering, hand brake that isn't, rubber-band CVT, etc....
    So.
    Our Priuses don't need a tachometer because there is no mechanical connection between your right foot and the engine compartment.
    In other words....it's what people sometimes call 'fly-by-wire.'
    When you stomp on the accelerator pedal, you're merely sending a polite request to the engine room asking Scotty for more power.
    If the squirrels are already running as fast as they can, then instead of a snarky reply in brogue you merely get ignored.
    You can.....and I have, placed a heavy object on the accelerator pedal and left the car unattended for a long period of time.
    You can.....and I have, placed the car in Neutral and stomped on the accelerator pedal for over a minute without anything much happening in the engine room.
    Spoiler Alert:
    The transmission (CVT) works the same way.
    You can.....and I have placed the car in Reverse while driving on the interstate.
    You can.....and I have placed the car into drive while still rolling backwards after backing out of a driveway. (It's just another form of PnG!)
    Here's the thing.
    Someone wiser than me once said that if you can't drive Priuses like [sic] normal cars, then you're missing the whole point of how seamless the folks in Aichi Japan made the car.
    Priuses are a little more fragile than some other cars, but only because of their diminutive ground clearance, and glass-jaw front end.
    If you avoid bumping into things, keep the car on paved roads, and avoid deep water on the road, then pretty much everything else will take care of itself.
    You should avoid deep water anyway.....
    See also: Natural Selection.
    Good Luck!
    TomInRockville and GrGramps like this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    8,257
    4,900
    Texas Hill Country
    It is true that the cruise control "steps down" too much in order to keep speed when a driver can do the same without as much revving. The driver is probably allowing a little more plus and minus time to keep the speed on a steep hill. As a result I might use cruise on relatively flat highways but not hill country roads with fairly steep uphills.
    CR94 and DGH like this.
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    As already stated, its completely impossible to over-speed a Prius engine, and there's no reason not to use the speed control and let it scream up those hills. BTW, Raton pass is for pussies - they shouldn't even be allowed to call it a "pass". Red Mountain Pass (US 550) is a "pass".
  5. CR94
    CR94 Senior Member
    2,642
    1,140
    Northwestern S.C.
    That's true of nearly all recent cars. There's nothing special about the Prius in that respect.
    It does need a tachometer, in my opinion. If it had one, you could see how fast it's actually spinning on those grades, instead of being unduly alarmed at "revving" noise that's hard to interpret.
  6. ETC(SS)
    6,589
    See how fast what is spinning? ;)
  7. TomNat
    31
    2015 Prius v wagon
    Thanks for the reassuring responses! On relatively flat interstates like I10 & I95 in FL, our Prius V at 75 mph on cruise control is fairly quiet & rarely goes into the red power zone on the HSI; so we were surprised by the engine roar/high RPMs when we climbed the 6% grade Raton pass.
    The good news is that our fully loaded Prius v could maintain 65 mph on a long 6% grade. We also did not notice any mpg hit using AC in the ECO mode. We went from 87 octane gas in FL to 86 & finally 85 octane in Colorado.
  8. Topp Cat
    Topp Cat Member
    71
    66
    I installed a scan gage ll monitoring rpm, engine temp, I don't use cruise control on steep long upgrades, yes prolong high rpm w high outside temp can cause overheating. That will leads to Mechanical failures! I try to keep rpm below 4,000 on steep upgrades, and watch engine temp normal is around 200 degrees anything above 220+is running hot. Without Gage's your clueless!
  9. TomNat
    31
    2015 Prius v wagon
    If you do not use cruise control on long 6% upgrades, what mode do you suggest, i.e. power or normal. We normally use Eco, but it seems you would have press the accelerator very hard in Eco mode to maintain 60-65mph.
    What speed will a Prius v at 4000 rpm maintain on a 6% upgrade. How does the Prius v performance degrade with increasing altitude?
  10. Air_Boss
    Air_Boss Senior Member
    4,007
    1,099
    New Yawk
    I hand-fly the steep upgrades. Drive Mode doesn't matter, you are holding speed with your calibrated right foot as opposed to the car doing it via its cruise control logic.
    There is no degradation in electric motor output with altitude, while the internal combustion engine typically loses 2-3.5% power per 1000 feet altitude increase due to reduced air density and oxygen content (fuel injected less due to better OAT and MAF sensing, carbureted more). Not used on the Prius, but supercharging or turbocharging or compounding (both) induction air can delay the power lapse rate.
  11. rdgrimes
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    There's no reason at all not to use the speed control. Seriously, the system is designed to do exactly what it does. If you do use speed control, it makes no difference what mode you're in - they're all the same when speed control is used. For that matter at highway speeds it really doesn't much matter what mode you're in anyway. There's also no risk of over-heating in a properly functioning system.
  12. TomNat
    31
    2015 Prius v wagon
    When switching out of cruise control in ECO at 65-75 mph, it seems that you have to press the accelerator pedal very hard to maintain speed; so maybe power or normal modes would be more comfortable for the right leg.
    We will try it now that we are back in Colorado!
  13. Topp Cat
    Topp Cat Member
    71
    66
    Hotter temp= low density of air, leaner mixture= higher combustion temp, higher Rpms = higher temps, higher altitude less density engine will run leaner, a/c on , condenser coil heats up , hot air flow thu radiator fins all these conditions will cause overheat no matter what! Why do they blow mass volume of air thu the raditor on dyno???
