High squeaky noice when Prius turned off
Discussion in 'Gen 2 Prius Main Forum' started by ward.ken, Feb 13, 2010.
  1. ward.ken
    ward.ken Junior Member
    Utah
    I
    Hi...when I turn my car off, about 25% of the time I get a high sqeaky noise coming from the front of the vehicle. I took the car into the dealer twice and received the same answer. They say it is the radiator fluid going back into the reservoir and that it's "normal" in the design of the vehicle.
    I don't believe them. Has anyone out there had the same problem? If so, what did they do to fix it?
    Ken
  2. ma55
    ma55 Junior Member
    Yeah...got the same noise, is normal...some are louder than others...not to worry...
    Mike
  3. larry9901
    larry9901 Junior Member
    44
    michigan
  4. Hodag71
    Hodag71 New Member
    Colorado Springs
    I have a 2009... and mine does this too. Larry, do you know if there was another TSB that applies to '09?
  5. larry9901
    44
    michigan
    I dont think this applies to the 2009, but I'll do some digging
  6. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    I encountered this problem once, when I started a different car ... turned out to be a cat that used up a couple of those lives that day. :eek:
    Do you only hear the noise when the ICE has been running?
  7. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
  8. dmdiver
    dmdiver New Member
    17
    My manual says it's normal to hear the water pump after turning off the engine. I thought that's what that noise was.
  9. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    It is normal to hear the pump push coolant into the thermos container after shutting down the car.
    But it should not squeek, or make a surging squeek. It should be like a hum.
    As mentioned, there is a TSB and a Toyota dealer should repair it for you. There is a newer version of the pump which does not have this problem. The waranty repair is for 5 years/60K miles.
    My 2006 started making this noise in the winter of 2008/9, stopped making it when weather warmed up in 2009, and is making it again in the winter of 2009/10.
    So, if you wait too long, you might not be able to proove your car does this, before the waranty on it runs out.
  10. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    509
    63
    Please let us know if you find something. My 2009 has been doing this since day one and I have been assuming it is normal until seeing some related threads here.
  11. ward.ken
    Utah
    I
    I'm not sure what ICE is but I will take larry's advice and go back to the dealer with the Technical Service Bulletin in my hand and have them replace the coolant heat storage water pump.
