high temp. for seconds then disappear
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by othman, Nov 17, 2010.
  1. othman
    othman New Member
    jordan
    hello everyone
    my name is obviously othman,
    i'm new to this forum as a member but old as a guest :D
    i always check this site & it's really a great one with many well knowledged prius owners;)
    i have a 2007 prius which is of USA type; i don't know how to figure out the type & the specifications which were mandatory during registration so i've left them as N/A :p
    so getting into the problem, before about a month my dad has lightly knocked the car with a wall at the front left side of the car. the coolant tank has been pushed & the pump has started giving abnormal noise whenever running
    but the problem is that i got a check engine light with the red triangle & a sign on the multi-information display..
    i have pulled the tank to its right place & released the pump after cleaning the calcification.. and so the noise has stopped.. & i have disconnected the battery during working & so the error code has gone
    after about one day the check engine light has came back alone.. & the reading was P1150 which means a coolant path clog
    i have tried all i can & done some tests; the water temp. in the coolant tank is hot even after hours of driving, i think there's no clot because when i cleaned the pump i have puffed into the tubes after disconnecting some connections & the air was going out easily from all openings
    i have resetted the error code 2 times
    now i'm having a new phenomenon.. in the past 2 days during driving & especially when i pull hard on the pedal & when the battery is in its lowest level --> suddenly the red triangle show up with sign that indicate a high temperature on the multi. display.. the funny part is that these signs don't remain more than 3-5 seconds & then disappear!!
    i don't know what does that exactly mean!
    i haven't gone to the dealer because he has a very bad reputation around here & he's the only in my country.. also the cost is very high with very low skilled workers as described by a mechanical engineer who worked there for a month
    i hope someone here would help to understand what's happening or what i can do
    thx in advance :)
  2. Patrick Wong
    18,210
    6,513
    DTC P1150 might mean a coolant system clog but it also could be caused by:
    1. CHS tank outlet temperature sensor
    2. Coolant flow control valve
    3. ECM (aka engine ECU)
    Since the symptoms started immediately after your dad's little accident, I would start by checking the temperature sensor mounted at the output of the coolant tank. First, measure the resistance of the sensor while it is installed. The resistance should be somewhere around 2K-3K ohms at temperatures around 25 - 30 degrees C.
    Then remove the sensor and see how it responds to very cold and very hot water. Put it in a cup with ice water, and measure the sensor resistance, which should increase to around 6K ohms or so. In boiling water the resistance should decline to around 200 ohms. Keep water off the sensor terminals.
    If the sensor is producing erroneous readings, this may cause the ECM to think that the coolant flow is impaired.
    Regarding the momentary high temp indication, have you checked engine coolant level at the reservoir mounted behind the radiator, as well as at the radiator cap when the engine is cold? You need to remove the black plastic cover over the radiator to access the cap, and use Toyota Super Long Life Coolant to refill as needed (pink color coolant.)
    Good luck.
  3. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    " Hot water temperature in the coolant tank" Are you referring to the thermos bottle? If so, under hard driving, that water will eventually get hot, as the hot water from the engine cooling system also circulates thru the thermos bottle. At that point the radiator should be warm to hot and the radiator cap should also be warm to hot and release with pressure. The Prius is not a hot running car, I recently changed the inverter pump and put new coolant in and had extreme difficulty getting the thermostat to open. Perhaps the temperatures in Jordan are much hotter than California. Electronically I can't suggest anything, I will leave that up to Pat. When the engine,and radiator are hot, can you see any turbulence at the open radiator cap? On a normal car, that is the case, on a Prius, I don't know. What is the temperature at the radiator cap, when hot? Measure it with a thermometer. If that temp is hot then your thermostat is opening and you have some blockage somewhere. (Be careful removing cap and use a rag) I assume the inverter cooling system is normal?.It may sound crazy but are you turning the cars heating system to maximum to allow total recirculation? This is also a method for cooling a overheated engine/ water circulation system. That's all I can think of: :D One more point, after opening up the engine coolant system, did you bleed all the air out ? Look at Coolant heat storage on PriusChat.
  4. Bob64
    1,540
    93
    Virginia
    did anyone mess with the radiator fan?
    Perhaps the blades are reversed?
  5. andyprius
    2,212
    188
    Hello Othman, How are you and your Prius doing?
  6. northwichita
    481
    102
    29
    Wichita KS
    I've never seen the high temp icon, my web search found:
    Red thermometer over horizontal wavy lines on MFD - high coolant temperature warning light. If this goes off, do see your dealer, as you shouldn't see this unless something is mechanically wrong. (Prius driven through Death Valley at high speeds in the summer don't even get this...)
    Red car with an exclamation point on it on MFD - hybrid system warning light. If this goes off, do see your dealer, as you shouldn't see this unless something is mechanically wrong.
    so, you did see the first one, right? I could see the second icon being misinterpreted for the first.
  7. othman
    othman New Member
    jordan
    i'm extremely sry because there was a problem in my computer!!
    Patrick Wong => thank you very much.. truly when i posted this thread i wished you would respond to me & turned out you to be the first to post.. i'm a car-mechanic lover.. but i don't have such devices.. i try to understand how the part should work & if there's any error in its job.
    & about the fluid level i should say that i noticed that it was getting lower every 2-3 days or even less..
    it was a very stressful days
    i went to the dealer & the engineer there showed me that the fluid in the coolant cap beside the inverter is NOT mixing-up & moving while the car is on IG-ON which i didn't notice b4 he said
    he told me that i should change the inverter pump just below the left light... i bought it & changed it alone.... but the problem did NOT disappear as it should be & the fluid is not mixing-up very actively as i remember when we bought the car; but still somewhat better than b4 changing the pump..
    finally i went so a normal mechanical who said he has worked for long years at the dealer's garage.. he told me to push hard at the fuel pedal while the gear is at (P) & i was shocked that it was giving normal sound for 3 seconds & then immediately stop & again as if i was pushing & then releasing & then immediately pushing in a very offensive way!!!
    he only added some water & then managed to reset the computer in the same way when i would change the oil (keep pushing over <trip> click & clicking the <power> button two times without the leg on the break pedal & then with pushing on the break pedal)
    the amazing thing which i still CAN'T understand & i hope someone would help me in the understanding is that the car didn't show any error or check engine light since then.
    also i forgot to say in my last post that i noticed when i want to turn the heater on it was not getting any hot air even if i keep it for half an hour!! & this thing started to happen b4 about 2 weeks or so; i'm not sure exactly when this problem started.. but the amazing thing is that when that guy re-setted my car's computer, the heater went back to normal
    i wish to understand what was the exact problem.. & did it resolve or just hidden someway by this maneuver?
    andyprius, Bob56 & northwichita ==> thanks alot 4 u too ;)
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
  9. othman
    othman New Member
    jordan
    edthefox5 ==> frankly i could not understand what did you mean!
    but i said that the heater problem is NO LONGER THERE..
    & pushing the pedal down will force the engine switching on & so it should be an indicative of any problem in the benzene passing into the engine & also any engine abnormality
  10. northwichita
    481
    102
    29
    Wichita KS
    i went so a normal mechanical . he told me to push hard at the fuel pedal while the gear is at (P)
    If your car functions normally with no error codes, the engine problem should be fixed. Accelerating the engine is useful in getting the air pockets out of the engine coolant loop ( it increases the pressure in the coolant system) , resetting the light is only an electronic 'coincidence' in this case.
    Accelerating the engine will not affect the inverter coolant pump. You say
    Here is a video of a prius inverter reservoir , it is low pressure, but you can definitely see flow. How does it compare to yours?
    YouTube - Gen 2 Prius Inverter Water Pump Flow
  11. othman
    othman New Member
    jordan
    thank you northwichita 4 following up with me :)
    that's exactly how it used to be when we bought the car.. but as i said now it's a little bit less turbulent now
    & yes i think accelerating the engine has done its job but what i still don't understand is the immediate stop & the very immediate engine warming up again
    i'm still afraid of accelerating the engine again at <P> so i don't get that reaction of the engine
    i think today i'll encourage myself to do it as a check.. :D
  12. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Your posts are hard to read and understand.
    Just trying to help you.
    Please see jdenenburg's new post in Gen II Main Forum concerning new
    recall on Inverter pump failures causing high temp spike.
  13. magic-man
    magic-man New Member
    31
    Trinidad
    Ok... I have seen this issue before, and it is easy to fix. I did mine myself.
    Here is what I have gotten from your posts that have lead me to the fix...
    The front end was struck and you moved the pump and coolant tank. You opened it to inspect it.
    You had an intermittant heat warning light...
    The part that gave me the biggest clue to your issue with the heater not working.
    I had the same problem when the dealer replaced the coolant bottle on mine and did not completely bleed all the air out of the system. It was Friday night on a holiday weekend and I had to work (50 mines away) the next night... Even a SMALL bit of air will cause a problem with the Prius.
    How to fix it:
    Get a gallon of the special LL coolant for the Prius from the dealer or NAPA (make sure its the RIGHT stuff (pink)).
    Park the Prius on as level a place front to rear as possible or with the front slightly raised (like in the driveway) (curb is OK in front of the house).
    With the engine COLD:
    ***** BLOCK THE WHEELS AND SET THE EMERGENCY BRAKE *****
    Remove the plastic cover over the radiator.
    Remove the radiator cap.
    Squeeze the top and bottom radiator hoses a few times to expel air in them.
    Pour coolant into the radiator until it is halfway to the top.
    Squeeze the top and bottom radiator hoses a few more times to expel air in them. When the level drops in the radiator, add more coolant.
    On the right side of the radiator (fender), there is a hole. Look into the hole. There is a hex nut there (to purge the air). Turn the nut to the left. Pour coolant into the radiator until it just starts to come out the hole, then turn the wrench right to close it.
    At sevaral points in this, you can squish the hoses to let out more air.
    Leave the radiator cap off.
    Now the fun part. Be careful from here on! The coolant will get HOT!!!!!!!!!
    With the EMERGENCY BRAKE ON, press in the normal brake and hit the power button (ready mode). Open the windows. Turn the heater temperature all the way to its highest setting. The engine will start and will cycle on and off every few minutes.
    While the engine is warming up, keep topping off the coolant.
    At some point, the thermostat will open. You will notice a sudden drop in the coolant level, so be ready to add coolant!
    It should take about 30-45 minutes to get the air out of there.
    I knew it was fine when I was getting a lot of heat out of the heater.
    When you are done, button things up and top off the resevior (sp).
    In a day or 2, remove the panel again and check the level. U might have to do the bleed procedure again (I did not), especially if you hear air bubbles in the heater. Keep an eye on the levels in the reservior... If it gets lower, you still have air in there that is getting expelled.
    And... Here is an official :welcome: to the forum!!!!!
    And... You could always pay the dealer $150-$200.00 to do this with their magic vacuum thingy...
  14. othman
    othman New Member
    jordan
    thx alot magic-man
    i think it has completely been solved
    thx again to everyone & sry if my language was not good
  15. AbuS3ood
    AbuS3ood Member
    113
    Jordan
    welcome to the club man, i thought im the only one in Jordan and says the only toyota dealership is bad, im also doing and fixing stuff my self with help from the great guys here :)
  16. bikr357
    bikr357 Plugged in Member
    63
    23
    16
    Houston, Texas
    MANY Thank's to magic-man... your procedure was just the trick to get the air out of my coolant loop after having to swap out the coolant hoses to the air intake. Doing so allowed me to clear two error codes P1121 & P1150 that were caused by air in my coolant loop.
