High temp light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ed480, Jul 25, 2023.
  1. Ed480
    Ed480 Junior Member
    Mesa
    Ok so my high temp light came on again going uphill. My question is if I have a bad head gasket would it always over heat and not only going uphill? Also if the head gasket is bad wouldn’t I lose coolant or have it mixes in my oil? I am not losing coolant or have any in my oil. I only change the rotor in the water with the thermostat can it be other parts bad in the water pump other than the rotor?
  2. Brian1954
    Brian1954 Senior Member
    2,207
    867
    South Central PA, USA
    Why did you create a new thread for the same problem??? You should continue this discussion in the original thread:https://priuschat.com/index.php?posts/3367194 . That way, people will see everything in one thread and not in multiple threads. Post your questions in the original thread and I will respond there.
