High voltage battery pack fan
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by FirstFlight, May 23, 2012.
  1. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    I've read a few stories on here about how the battery fan was clogged with a lot of dirt, fur, lint, etc. I decided to take mine out and inspect it. It was in pretty good shape, just a light coating of dust.
    I measured the resistance and got 4.23 ohms. Also, I turned it by hand and it seemed to be a little tougher to turn than I anticipated.
    My battery does get warm and I can never hear my fan running. However, I just got my scangauge so I have no measurements to compare it to. I did verify that the fan works when the battery gets warm. My additional questions are:
    1. Should the fan turn freely and easily or have a small amount of resistance?
    2. Is 4.23 ohms correct? (more than 2 amps seems excessive)
    3. How many speeds does the fan have?
  2. cnschult
    cnschult Active Member
    772
    97
    Michigan
    4.23 ohms is nothing, I've built circuits with tiny resistors that were 2-10 kilo-ohms.
  3. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    Huh?
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Yeah, that is a pretty funning response. I hope he was joking. If not, I have some 100 Mega Ohm resistors, so that that.
    :p
    Tom
  5. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    Yeah. A fan that needs a 10-20K resistor should cool the battery pack nicely. :nono:
    Bigger isn't always better;)
  6. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
