High Voltage Cables & First Responders
Discussion in 'Gen 2 Prius Technical Discussion' started by CyberBiker, Feb 3, 2008.
  1. CyberBiker
    CyberBiker New Member
    I hope this is a reasonable place for this question.
    Please Consider:
    My son is a Fireman/Paramedic and does first responder work for both of the organizations he works for. He posed a question that I have been unable to find an answer for, so I thought I would see what the pundits here had to say about the question or a source for the answer.
    It is my understanding that the High Voltage wire coming from the Main Battery Pack to the Electric motor is orange.
    What happens if that cable has to be cut by the first responder at an accident?
    What Precautions need to be used in handling a damaged high voltage system?
    It seems there should be a fuse that would cut off current from the battery, is there one?
    Where is it?
    Thanks for your help
    p.s. How can I fix this signature thing. It is supposed to be the GreenHybrid MPG data link.
  2. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
  3. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    that reminds me, i need to send that info to my dad.
  4. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Why didn't he contact Toyota? Doesn't his local certification authority keep up with things? Hybrid technology isn't exactly new.
  5. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    For the signature, see this thread. You need to use vBulletin's link formats, not standard HTML.
