Higher mileage maintenance schedule?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by djkarrels, May 10, 2012.
  1. djkarrels
    djkarrels beermandave
    Wauwatosa, WI
    Hi all, mine has 160,000 miles on it and change and got an email today from the dealership that it's time for its service. Just had oil change and rotation done. Every 5,000 miles and change. Finally had to get the front brakes done. Is there a link to what services are needed when for the Gen II Prius(es) with higher miles?
    Thanks
  2. jdenenberg
    jdenenberg EE Professor
    3,860
    1,859
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Just extend the schedule using the time/miles period for each scheduled item in your owners manual.
    JeffD
  3. Patrick Wong
    18,200
    6,479
    In addition, I would suggest that you consider replacing rubber engine compartment parts such as the serpentine drive belt at minimum; and radiator hoses if they show any signs of cracking when you squeeze them. Transaxle ATF change at 60K mile intervals, at least.
