Higher weight oil in Hot climates?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ramdisk01, Jun 7, 2011.
  1. ramdisk01
    ramdisk01 Junior Member
    Merritt Island, FL
    A few years ago we used heavier oils in warm climates, eg. SAE 40, and lighter oils in cold climates SAE 30. As time went on multiviscosity bcame available and put these thoughts in the backround.
    Now, with multiviscosity sythetics, Is the much praised 0-20 sae, the best for all climates...(albeit it is canonized by the Toyota Motor Company.)?
    In my central florida climate, I ran my previous car with Sythetic M1 15/50 over 200K miles with excellent results. I would appreciate any thougts.:rolleyes:
  2. Launch Vehicle
    Launch Vehicle Junior Member
    82
    Missouri
    Lots of start-ups require water-like viscosity. But you raise an excellent point - why not at least kick the first number up to say, five - in areas prone to being hot year round?
  3. situationalawareness
    83
    43
    San Tan Valley, AZ
    Thankfully, with synthetic the viscosity has allowed it to stay intact and useful at much higher temperatures.
    I've used 0w20 in my 2008 Prius in 115 degree temps continuously without any problems, at all. Of course, I use Amsoil synthetic oil & filters. I have a 2011 right now that is 1 day brand new, so I can't speak for Gen 3 oil changes :)
    I'm in Phoenix, AZ.
  4. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    For crying out loud, we are talking about synthetic oil here, not the same as paraffin based stuff we used years ago.
    Leave well enough alone.
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    There is no reason to up the 0W in hot areas. 0w gives you a bit better fuel economy when the engine is till warming up to full operating temperature than 5W does with no drawbacks in a synthetic oil.
    If you wanted to muck with oil viscosity because of high temperatures, going from a 20 to a 30 would make more sense, but so far I'm not aware of any reason to do it on a Prius
    jcaprani likes this.
  6. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,803
    1,170
    Auburdale FL
    I use 0w30 in my 2009. However since the dealer has to pay for the oil in my 2011 0w20 is good enough. 0w30 is my preferred oil!
  7. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    No need the oil thats recomended is way better than higher weight dino oil. Plus if you went to a higher weight oil you will loose mpg.
