Highway better than City - why?
Discussion in 'Gen 2 Prius Fuel Economy' started by kocho, Feb 20, 2008.
  1. kocho
    kocho Member
    134
    Maryland
    I've had my '02 Prius for some 6K miles or so now since I bought it used at about 116K miles.
    It has been my observation that I get better mileage on the highway/secondary roads than in light or heavy city traffic. Why is this? Whouldn't it be the other way around?
    With my car warmed-up and in 50F ambient temp I was able to comfortably get 66+ mpg over 80 miles. The elevation difference b/w start and finish was negligible - at most 150 or so feet elevation drop if not less over 80 miles should be almost nothing I think. This was a mix of 50-62 mph highway and around 40-50 mph suburban roads with virtually no traffic lights.
    I did some gliding but not much pulsing. Meaning I did not accelerate in the pulse, then slow down with a glide, but instead kept the ICE running at most times so that it worked in the 50mph and above range and glided on the down-hils.
    Started with full battery, ended with full battery, so I'm not cheating here. After another 20 miles of city/highway commute (including one cold start today + 10 miles) my mileage declined only slightly to 63 mpg.
    My regular mileage in 60/40 city/highway comute is usually around 45 mpg, but this is at exceeding the speed limit slightly.
    This time around to get this 66+ mpg I was not in a hurry and was driving at or slightly below the highway limits and at or slightly above the secondary road limits - this seems to be the key difference and the lack of sudden acceleration/deceleration with brakes to keep-up with traffic.
    Just before this trip, I did another 300 or so miles at 55+ mpg at highway speeds and keeping at the speed limit or slightly exceeding it (65 mph limit). Round-trip on the same roads, so elevation (going downhill) is not the trick. I've done other long trips at 50+ mpg on the highway, so it is not a fluke.
    Any thoughts? Is it just that Washington DC/VA/MD urban traffic is too jerky and "competitive" to keep-up with, thus too much loss in tracktion brakes and in heavier than optimal acceleration?
  2. bwilson4web
    16,010
    I have the same model, 2003 NHW11 Prius and the key is to understand the control laws. In particular, transitions through 42 MPH are a mileage killer. It is OK to stay say 3-4 mph below or 3-4 mph above but don't transit 42 mph if you can help it. You also need to understand the warm-up cycle.
    Below 42 mph, the car will efficiency cycle between gas and electric power and a warmed-up, S3/S4 state Prius will excel. Above 42 mph, the car will efficiently augment engine power and again, your mileage will excel even though the engine must run at all times. It is the transition between these two states that boluxes up the mileage:
    Warm-up is important too, especially the transition to S3/S4 at a stop. After the engine coolant reaches 70C, you need to come to a complete stop and let the ICE 'auto-shut.' Now sometimes, this can be a little tricky if the vehicle wants to put a charge on the battery.
    My S3/S4 trick is to come to a stop when the coolant reaches 70C (at least 5-6 minutes into the commute) and put the car in "N" for a slow, 10 second count, and then put it in "D". What happens is when in "N," the ICE will naturally idle down to the slowest possible rpm and apparently it takes some "n" seconds at a very low idle to set the "auto-stop" logic. When the car is put into "D," the 'auto-stop' logic does its magic and the ICE stops. Thereafter the car will use electric mode whenever it can. I have pulled into a parking lot with two exits to do this trick knowing that I won't have to worry about following traffic. A brief pause (and letting the rest of the traffic by) is all it takes.
    GOOD LUCK!
  3. ceric
    ceric New Member
    1,114
    Fremont, CA
    It is possible to get very good MPG in sub urban provided that you can
    - find a route with <40mph speed limit with very few stops/lights (ICE kicks in at 42mph no matter how gentle you drive)
    - accelerate mildly up to 40mph w/o being shot/shouted at by your fellow motorists.
  4. kocho
    kocho Member
    134
    Maryland
    That's what I've thought myself though I have no data to prove it. It just seems logical that the extra energy needed to turn the engine from 0 to whatever RPM around the 39mph mark would probably be significant.
    If I expect I'm going to be driving above 41 mph or so I much prefer not to go below that and avoid the ICE stopping completely.
    As for P&G below 41 mph, I'm not convinced that's the best mode for long-ish commutes - too much energy lost in charging/discharging the battery, stopping/starting the engine IMO. Again, got no data one way or another...
    I suppose the warm-up cycle is the culprit though. My commute is usually about 15 miles or so one way, starting from my underground garage (an advantage) and ending in an open parking lot for a complete cool-down during the day...
    It would be interesting to see data from a taxi driver or a delivery person in a city traffic to see how they are doing over long miles in traffic...
  5. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    I think this is part of the problem. Most of my local driving is in Arlington or DC, which means frequent stop signs, red lights and erratic driving going on all around me. Some routes are better depending on the time of day, e.g., I do better on Braddock Rd (Fairfax County, not Alexandria) or Route 50 inside the beltway if there is not too much traffic on them.
    Also the colder weather has a greater effect on the shorter trips than on long ones.
  6. bwilson4web
    16,010
    Please don't confuse the manual, "P&G" with the built-in control laws that switch between ICE and electric power automatically below 42 mph. Once you are in S3/S4 warm-up mode (pretty important,) all you have to do is avoid transiting 42 mph and just pay attention to traffic and your driving. The usual definition of "P&G" that I've read involves deliberate speed changes and accelerator tricks and is entirely different from just letting the Prius be itself. <grins>
    I'm not an advocate of "P&G" although I do use "N" during the warm-up to minimize fuel burn. This has to do with keeping the ICE at a minimum rpm and load as much as possible during warm-up. I don't do accelerator tricks although I've been thinking about an approach.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    If you are charging and discharging, then you are not really doing a pulse and glide; it would be more of an EV and Regen. You want to stay away from charge and discharge cycles for best mileage (obviously).
    Tom
  8. kocho
    kocho Member
    134
    Maryland
    That's right. I used the "P&G" term incorrectly. The "G" in it is the key ;). Thanks for catching this.
  9. bwilson4web
    16,010
    The EPA tests use the Prius in 'charge and discharge cycles.' If your goal is to achieve EPA test results, drive it as described in the EPA testing protocols. Since the EPA reduces their results by 10%, it is fairly easy to exceed EPA results. For better results, eliminate those parts of the tests that cause higher fuel consumption, like the start-and-stop cycles in the highway test.
  10. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    most people get worse mileage in city driving simply because it takes a lot more patience, understanding and concentration to get good mileage.
    you already know the answer as to why you get better mileage... "with almost no stops"
    that is why. accelerating one time is enough to lower your average over the next several miles... do it every 5 minutes, and you will get only average mileage.
    that is why in very heavy traffic, the Prius gets the worst mileage. you would think that averaging 15 mph would get you great mileage, but i have averaged as low as 30 mpg in stop and go...but that is because of the constant acceleration and the less than 3% energy recapture from regen
    to get the best mileage, drive 35 mph with no stops... but that is a very difficult route to find... as most have discovered, your best bet is a county road at 50 mph...there you can go several miles between stops and the reason your mileage soars has less to do with velocity than it does with the change in velocity or acceleration/deceleration.
  11. kocho
    kocho Member
    134
    Maryland
    This sounds like the explanation.
    It is of course clear to me that acceleration/decelleration wastes energy but I thought the EPA tests would have taken this into account. I did not know why the EPA estimates would be better in the City than on the Highway. Your information explains it and also why these estimates are not representative of the true potential of the Prius.
    Indeed in my lifetime average over 6K miles or so has been 45 mpg but the few times I've done highway (less than may be 500 miles out of the total) I've done at least 50 to 55 mpg without too much trouble.
    On the other hand, stop and go in heavy traffic as the other poster said, indeed cuts-down the economy a lot, especially when I do it for longer periods of time and my battery has gone down in charge significantly. In light city traffic where I can anticipate things better, my 40-45 mpg still holds well, usually...
    Thanks for the responses!
  12. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    The original EPA tests were developed in the 70s well before there were any hybrids. The additional tests aren't geared to any specific car type either. They measure unburned hydrocarbons out the tailpipe on very specific driving cycles and then fudge... err adjust the numbers downwards. See How Vehicles Are Tested and Fuel Economy Test Schedules.
    Beating the EPA - The Why’s and how to Hypermile. - CleanMPG Forums and Toyota's Prius-I, reaching for the hypermiler in all of us. - CleanMPG Forums should be helpful. I haven't read the latter in detail since I've read the one for my gen of Prius.
  13. rogerSC
    rogerSC Member
    170
    My highway mileage is always better than city. The area I live in has no idea about synchronizing lights that are just a few blocks apart...While my gas mileage commuting (mostly freeway/expressway style driving) is always over 50mpg, 57 or 58mpg in the summer, I can't do that around town, even though my car is warmed up. I am always accelerating then stopping shortly after that, which drives me crazy, but nobody else seems to mind.
    -Roger
  14. ken1784
    ken1784 SuperMID designer
    2,943
    1,381
    67
    Yokohama, JAPAN
  15. ForTheGlory
    ForTheGlory New Member
    296
    Maryland
    Question regarding the 42 mph barrier: When I was driving around yesterday, I was able to glide (with no arrows on the screen) up to about 48 mph. Any idea why that's possible?
  16. ken1784
    2,943
    1,381
    67
    Yokohama, JAPAN
    The energy screen is not an engine status screen. It just shows us the energy flow.
    The screen sometimes lies, such as warming up, S3a idling, above 42 mph spinning and etc...
    Ken@Japan
  17. bwilson4web
    16,010
    Thank you Ken,
    What you've suggested is the optimum distance profile is:
    1. maximum ICE efficient operation - split between motion and battery efficient charge
    2. efficient battery propulsion - avoid converting momentum into battery charge and excessive current drain
    With what we know about Prius performance, we should be able to develop a profile for the optimum driving profile given any route of known distance and altitude change. The key is understanding the route altitude profile to optimize performance. Some mild upgrades are desirable but long level or shallow downgrades are going to be the key.
  18. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    Right, no arrows only means no energy flow. You can see no arrows on the interstate at 65 (and higher I'm sure) with CC on if the slope is exactly right to maintain your speed with no regen braking and no energy added in from the ICE or electric motor. The ICE WILL be spinning, without using gas, if you see it over 42 MPH.
  19. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i still contend that no arrows only means energy flow below a detectable level or below the threshold to display change
    i have seen no arrows many times on freeway but still registering 400 mpg on scangauge. so that means someone somewhere is lying.
    many people report doing no arrow driving but still seeing their charge level reduced. granted, accessories do use some power, i sincerely doubt that it would be at a level that would cause you to lose a bar of charge in under 20 mins. (i have sat in place with no AC for 30 mins with radio on and never lost a bar. granted, not driving i m sure reduces power needs for the several onboard computers...)
  20. ken1784
    2,943
    1,381
    67
    Yokohama, JAPAN
    Yes, the scangauge is also lying.
    CleanMPG reviews the ScanGauge II. - CleanMPG Forums
    "Another issue has to do with Fuel Cut. The ScanGauge II has no way to tell if the ICE is in Fuel Cut or if the car is at speed running at idle as you would in a NICE-On. Although the FE calculated and shown is very high under this condition (between 130 and 250 MPG depending on speed and ICE size), fuel is still shown being consumed when it is not thus causing an ever increasing error to build in. If you were the type to decelerate in Fuel Cut with ICE-Braking vs. FAS’ing in a very hilly or mountainous area, this error could degrade the displayed FE accuracy sharply. This is no fault of the ScanGauge II given the OBD-II protocol does not have a Fuel Cut parameter for the ScanGauge II to use for determining when you may or may not be in Fuel Cut. It is however an issue that some owners may have to live with depending on their commutes terrain."
    Ken@Japan
