Highway Cruising MPG
Discussion in 'Prius c Main Forum' started by Hank101, Mar 14, 2012.
  1. Hank101
    Hank101 Member
    108
    SC
    What are your experiences on the highway steady cruising (65+MPH)?
    Factor-out city driving, and ramp on/off..
  2. Kirkuleez
    Kirkuleez New Member
    220
    24
    Oshkosh, Wisconsin
    Today going about 45 miles each way I averaged 59 mpg's heading North and 48 mpg's heading South against the wind. Highway usually averages close to 48-50ish. I've gotten as low as 42ish nd as high as 60ish.
  3. Kirkuleez
    220
    24
    Oshkosh, Wisconsin
    My city driving however, I've gotten as high as 89.2 and as long as I'm driving for a couple miles or more I get upper 50's to upper 60's on several occasionsn
  4. cubchan
    cubchan Junior Member
    42
    Indianapolis, IN
    My drive to work is mostly highway driving and I've gotten anywhere from 43-48. After the little bit of city driving getting off the highway I usually end up around 50mpg for the trip.
    Not caring about my speed? If I'm in a situation where I can hang out at 60-65mph then 50+mpg isn't a problem
  5. Kirkuleez
    220
    24
    Oshkosh, Wisconsin
    That's still darn good though.
  6. Hank101
    Hank101 Member
    108
    SC
    What speed?
  7. Kirkuleez
    220
    24
    Oshkosh, Wisconsin
    Primarily between 65 and 70, but there is is a couple small sections where the speed limit is 55 due to contruction so there it's usually 55 to 62.
