Highway Fuel Economy
Discussion in 'Gen 2 Prius Fuel Economy' started by WolfPrius, Aug 31, 2013.
  1. WolfPrius
    WolfPrius New Member
    Burbank, California
    So I just bought a 2004 prius with 197k miles. I've been getting roughly 38-39mpg on my commute. This is mostly due to traveling through mountainous terrain... San Fernando Valley to Santa Clarita. Anyway that can be suggested to get over the 40mpg mark? I've got Michelin Defender Xt tires and try to stay between 65-70 mph.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    It's the 65-70 MPH in the hills that is killing your mpg. Read up on the suggestions for increasing mpg on this site. You should be able to get in the 43-45 mpg range. But, your HV battery may be getting old at this point.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Be sure you are not still on the original 12 volt battery, ten years is a long time. So is five years.
  4. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    If you're getting 38-39 like that, dropping back to 60 should put you well over 40. PSI at 36-42, begin slowing or stopping further back costing longer, recapture more paid for energy from regen braking that places less demand on the ICE. So, a little slower and little sooner anticipation of stops can make the difference you are looking for.
    drysider likes this.
  5. ursle
    ursle Gas miser
    1,049
    192
    NH
    Well, not bad, better then anything else for the money, a new gen3 might get 48-50, 200,000 and still almost 40 on a mountainous route, if there's a scenic way and time try it sometime, but 65-70 is just to much for great mileage.
    12v has to hold a charge, trans-axle needs fresh fluid, don't carry any extra weight, you gotta do what you gotta do.
  6. fuzzy1
    10,652
  7. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
  8. WolfPrius
    Burbank, California
    Alright so I did a few things to test out based on research. One, staying at 60mph on the highway gave me much better results as far as mpg. I went out to Malibu yesterday. I was averaging closer to 45-50 just on that alone. Secondly I did a check of the 12v auxiliary battery. It appears to be low, reading 11.9v without a load, 11.2V with a load; so I will go get a battery after the holiday and install it myself. Air pressure set at 38 front 36 rear.
    - What fuel economy are you getting and how are you determining fuel economy? (trip computer or manual calculations) 36.1-38.3
    - What fuel economy are you expecting and why? 42-45mpg I'm pretty sure these get higher than that, however being that its ten years old, I'm
    expecting a little
    - What are the approximate outside air temps? 90-100 F
    - How long are your trips? 50-100 miles
    - How much of it is city vs. highway? Roughly what's the average speed in overall and and of each segment? Is there a lot of stop and go driving? All Highway, 60-65mph pretty straight on not many stop and goes
    - What region/state are you in? (if you haven't set your location in your profile) Los Angeles, CA
    - What's the terrain like of your drives? (e.g. flat, gentle hills, steep hills, etc.) Mountains
    - Is your oil overfilled? (i.e. above the full mark on the dipstick) no
    How old is your 12v battery? What is the voltage reading of your 12v battery after sitting over night? 11.9V after sitting overnight without a load, with load 11.3V
    Have you had your alignment checked? Any pulling or abnormal tire wear? No abnoral wear, no pulling, drives straight
    - Are you using the factory tires and wheels? If not, please indicate tire make, model and size (e.g. Goodyear Assurance Fuel Max 185/65R15). Factory size, Michelin Defender XT
    - What are your tire pressures? 38F 36R
    - Make, model, year, engine and transmission of previous car? (e.g. 08 Honda Civic Si 2.0L 4 cylinder, manual transmission) What did you actually get on the same trips/commute? (Please give us actual numbers, not EPA ratings.) 01, 4runner V6 auto, close to 15-19mpg
    - How are you trying to drive (e.g. trying to stay in electric only?) and how hard are you braking? speed limit, trying to be on electric as much as possible, trying to anticipate the braking
    - Are you "warming up" the ICE (internal combustion engine) by letting it idle after powering on? Not too much.
    - Are you driving using D or B mode? D
    - HVAC settings? Are you using the heater, AC, auto mode, etc.? If using auto, what temp is it set to? A/C running in Auto mode
    - If reporting a mileage drop, did anything significant change on your car (e.g. accident, hit a curb or big pothole throwing off alignment, oil change/other maintenance/repairs, changed tires or wheels, etc.) or your commute? Just bought the car, saw that it was pretty low on the mpg, so trying to figure it out.
  9. fuzzy1
    10,652
    Here are the first items that jump out at me:
    I don't believe that is low enough to be a big factor.
    What temperature is it set for? If LO, this would be a significant drain at these temperatures. Putting the setting into the upper 70s, and turning the fan down to the lowest speed that still provides adequate comfort, may help.
    For newbies, especially on the highway, let the car make its choice between electric and gasoline. Don't try to push it into electric, as it is much too easy to get lower MPG than the car can do when making up its own mind. Get some baseline results first, then try to improve later.
  10. dorunron
    3,318
    1,105
    Houston, TX
    Thanks for filling out the questionnaire. fuzzy1 above pretty much hit the points I would mention and the resolutions thereof. I will add the following.
    Concerning the A/C use try the following. When using the A/C set the temperature to 76 and use the "Auto" cycle. When the recirc turns off, turn it back on. Running the system in recirculate will help to keep the Prius cooler while lowering the load on the traction battery as the electric compressor does not have to cool incoming outside air.
    Concerning the driving trying to stay on electric I suggest you look into hypermiling. There is a link in my signature which will give you excellent information on it. You will get far better mileage if you employ the hypermiling technique instead of trying to drive on electric only. Note: We are talking about speeds anywhere between 0 and 42 MPH. Anything above 42 you pretty much have to go with the ICE, even though there are tricks there too that can be employed.
    Concerning your 12 volt battery. Your battery is very weak and should be changed soon. It would not surprise me if you are seeing the red triangle light up briefly when you push the Power button to go into ready mode. Regardless, the DC to DC converter which is the charging system is working overtime trying to keep your auxiliary battery charged. A fully charged 12 volt AGM type (Prius 12 volt type) normally reads on the test as follows.
    Aux Mode: 12.6 V and higher
    Ign. On Mode: 12.4 V and higher
    Ready Mode: 13.8 V to 14.2 V
    Many here will recommend the "Yellow Top" battery. Other's will recommend the OEM battery that is offered by Toyota dealers. Other's still will recommend alternative type of batteries. When I changed ours I went with the OEM type battery. I was able to do the work myself with just a few tools. Don't go to the dealer and ask them to do the job for you as the battery is expensive and the labor is high too! The average price for the battery ranges from $175 to $225 and the dealer will usually charge anywhere from $50 to $125 labor for the install. There is a link in my signature file that discusses how to change the battery.
    As you have already seen driving at a slower speed 60 vs 70 and higher does dramatically effect the overall MPG. When you can, try to keep your speed down. I am not saying to impede the flow of traffic. What I am saying is this, stay in the right lane of the traffic and go with the flow. When you have time and there is no other traffic around, set the cruise on 55 and let it roll.
    Last point: Michelin Defender's are a good long lasting tire. However they are not one of the "best" tires when it comes down to efficiency. When it comes time to change them, consider either the Bridgestone Ecopia 422 or the Michelin Energy Saver A/S. Also, 38F and 36R is not bad. However, if you can tolerate the rougher ride try 42F, 40R. Those few extra pounds of pressure will make a difference too.
    If you haven't done so, check and or replace the air filter for the ICE. Also, concerning the oil. If you are not running synthetic, you should consider it. That too should help you to achieve higher MPG. Keep the oil between the two dimples on the dip stick. Do NOT overfill as that will cause problems.
    Once you get used to driving a Prius and learn how to hyper mile you should find that you will easily meet and or beat the EPA estimates.
    Best of luck to you and welcome to Prius Chat!
    SteveLee likes this.
