highway gas mileage
Discussion in 'Gen 3 Prius Fuel Economy' started by Ddg, Sep 5, 2010.
  1. Ddg
    Ddg New Member
    new england
    hi - what type of gas mileage do you get at 75 miles per hour?
  2. cproaudio
    cproaudio Speedlock Overrider
    2,401
    759
    CA
    probably about 40-45
  3. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
  4. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    It depends on alot. Hills? OR the outside temp? I seem to get 55mpg at 55-65 mph and 50mpg going 70-75.
  5. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    At 75 I get about 47-49
    at 65 I get about 55
    That was on ABOUT 200 MILE ROUND TRIP
    Also my car is load with ladder , carts, cases, tools, I can not see out the back of the car
  6. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    I try not to drive 75+ mph. On a short drive, 75 will not hurt, but I recently drove a 4500 mile trip, mostly Interstate, and I set the cruise on 73mph. Overall, my indicated mileage was 52.+, which actual is about 49 mpg. I find 73 to be restful; we listen to books on CD; the Prius is quiet, and I can drive all day at that speed and not be weary. It works for me.
  7. austingreen
    austingreen Senior Member
    13,574
    4,114
    Austin, TX, USA
    On a 2 mile trip with air conditioning about 35mpg same as 65mph. On longer trips you seem to lose 0.5-1 mpg for every mph when you start getting over 70. Its not much of a hit depending on your pov. If your doing a long trip at high speeds make sure your tires are pumped up first as this is more important at higher speeds.
  8. rpeek2
    rpeek2 Dry Ice Juggler
    149
    MidwayUSA
    Just got back from a 1100 mile, 72MPH cruise set weekender. Tailwind for 600 miles, headwind for 500. Indicated 55 MPG and 49 respectively. Actual about 50 calculated average. FYI: 70MPH @speedo is 69 according to my garmin. I'd say the computer indicated digits are a bit subjective.
  9. Airbalancer
    892
    73
    Cobourg, On, Canada
    Why do people all ways think the GPS is perfect?
    These are not military grade
    I will be in my driveway put my garmin will indicate I still 20 metres to go
    Also the Garmin could be reading 69.4 and the car could be 69.6
    which way they round up or down
  10. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    GPS is pretty darn accurate on speed. I've found my Garmin to consistently be 1 mph below the indicated speed of the Prius at highway speeds. I've found my Prius to consistently be 1 mph high on a measured mile. I've found my Prius to be 1 mph high as measured by laser radar operated by a friend of mine who is on the NCHP.
    BTW the Prius does rounding as well. I assume both round .1 to .4 down and .5 to .9 up by design. Wouldn't make sense to do it any other way.
  11. Ddg
    Ddg New Member
    new england
    Thanks all!
  12. Airbalancer
    892
    73
    Cobourg, On, Canada
    Have you calbratied GPS with something ?
    People are too hung up about +/- 2 mph / 2 mpg
  13. PriusG3IV
    PriusG3IV New Member
    37
    Kentucky
    I picked up my Prius on Friday and drove to a Family reunion yesterday.
    3 adults, no luggage but 1 heavy cooler.
    740 miles round trip. 11 hours. 47.7 mpg indicated.
    Speed varied (as per the instructions for the first ~600 miles) but stayed mostly between 73 ~ 75 as it was almost all Interstate driving.
    I could watch the mpg indicator slowly rise as the speed was kept between 60~65 and then slowly fall as the speed increased to 70~75. When we went through major metropolitan areas (2 on the dirve there and back) the mpg indicated would rise at an increased rate the the mph average dropped to ~50.
  14. Downrange
    Downrange Active Member
    360
    189
    2024 Prius Prime
    SE
    My .02: avoid cruise control, unless you're on very flat terrain; it will brake (regen) downhills and then go hi-revs up the next grade - horrible for fuel economy.
    Best bet is to ride the terrain - let it get going down hills, then gradually lose momentum going up.
    I got 52 mpg going back home from beach - up hill a lot - running 60-70 most of the way.
  15. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    At an actual 75 MPH (indicated 77 to 78) I usually get 44 to 46 on fairly level terrain with no wind.
  16. Canard
    Canard Member
    208
    38
    Ontario, Canada
    I'm getting really excited (I take delivery in about a week) to read about the great FE at higher speeds. :)
    -Iain
  17. jburns
    829
    111
    Archdale, NC
    As I said in my post the GPS was spot on laser radar. Close enough for me.
  18. Airbalancer
    892
    73
    Cobourg, On, Canada
    Ooops missed the part about the lazer, I need a bigger screen :D
  19. Canard
    Canard Member
    208
    38
    Ontario, Canada
    I think GPS speed readings will always be near-perfect, regardless of positional calibration, because it's a calculated average polled location points.
    Car speedometers always have to read a few mi/h or km/h over the car's actual speed, because a) it can never be absolutely perfect (physically impossible) and b) since it has to be slightly off, it's safer to err on the over-reading side vs. the other way around, where you could arguably get a ticket for doing what you thought was the speed limit.
    -Iain
  20. dcscm1
    dcscm1 New Member
    31
    Atlanta
    I have the same to report as Tumbleweed. On round trips from Atlanta to Florida, with cruise set to 77, I regularly get 46.
