Hill Start Assist HSA- Can it be switched on for longer than 2 secs?
Discussion in 'Gen 3 Prius Main Forum' started by garytail, Sep 15, 2010.
  1. garytail
    garytail Junior Member
    Thousand Oaks, CA
    On my new 2010 V ATP, I was wondering if the Hill Start Assist could be switched on for longer than 2 seconds. It would be very helpful in traffic and at stoplights to be able to "lock it on" until one needs to move again.
  2. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    I thought that once you set it it stayed until you pressed the gas... I've never tried it, pretty flat here, so don't know for sure. Used to have it in a Nissan Frontier, and once you set it it would hold until you pressed on the gas pedal...
  3. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Traffic and stoplights? I don't think it's designed for that.
  4. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    Sounds useful but what about liability if it does not stay on or if the driver just thinks its on?
  5. silverfog
    silverfog New Member
    152
    23
    Raleigh,nc
    Yes. Press hard on the brake to turn on HSA. Then keep your foot on the brake with just enough pressure to keep the HSA indicator light on. Your 2 seconds starts from the time you release your foot.
  6. garytail
    Thousand Oaks, CA
    Thanks, I'll give that a try but was really hoping to be able to take my foot off completely.
  7. silentak1
    silentak1 Since 2005
    893
    28
    LA
    +1. This works, after HSA is engaged you don't need to keep applying as much pressure on the brake, just medium and it stays on.
  8. garytail
    Thousand Oaks, CA
    I'll have plenty of time to try this on the drive home tonight on PCH (Pacific Coast Highway):)
  9. Tideland Prius
    16,151
    Yeah... that auto-hold feature is only available on luxury cars for now.. .it'll filter now eventually...
  10. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    The point of the two seconds is to allow sufficient time for your foot to leave the brake pedal and find the accelerator to prevent rolling backward.
    It's not intended to substitute adequate brake pressure to keep you in place (i.e. a foot rest). If you don't want to move and want to keep your foot off the brake, place the vehicle in Park.
    Having brakes on though keeps the lights on for the driver behind so he knows when you're going to move and when you're not.
  11. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    PHC isn't hilly and I don't understand why you want to do all this extra work to activate Hill Start Assist every time you stop.
