Hints Regarding Replacement of 2G Front Struts
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Patrick Wong, Oct 10, 2009.
  1. Patrick Wong
    18,200
    6,479
    My 2004 has 90K miles. A couple of months ago, while changing the engine oil, I noticed that the RF strut looked nice and shiny. Further examination revealed that it was covered in strut oil. I was about to embark on a five-week-long trip to the East Coast, so I had to defer replacing the front struts until this weekend. In the meantime I ordered the parts from Champion Toyota, Houston:
    48510-49495 Shock Absorber Assembly MSRP $131, Net $99
    48520-49585 Shock Absorber Assembly MSRP $131, Net $99
    48609-13010 Support Subassembly MSRP $87, Net $66 (need qty. 2)
    48158-47010 Front Coil Spring Insulator Lower MSRP $14, Net $10 (need qty. 2)
    48157-02070 Front Coil Spring Insulator Upper MSRP $21, Net $16 (need qty. 2)
    Hence, a total of $382 plus shipping. Freight was $42 but I also bought several filters. Maybe the freight charge would be slightly less without those.
    Note that there are two different part numbers for the struts since one is for the left while the other is for the right.
    I strongly recommend that DIYers download the necessary repair pages from techinfo.toyota.com to get the exploded parts diagram and instructions. In this post I will point out suggested changes to the Toyota repair instructions. I am using part names per those instructions.
    The "front coil spring seat upper" has an oblong hole that locks into the top of the shiny chrome shaft of the front shock absorber assembly. The repair instructions prescribe an SST to lock the spring seat in place when it is time to remove the top nut. Otherwise, the chrome shaft will rotate while you are trying to remove the nut.
    I don't have the SST and tried to use visegrips on the chrome shaft when taking apart the RF strut. However they slipped. I finally used a small screwdriver inserted into a hole in the spring seat, to hold the seat stationary and allow loosening of the nut. The screwdriver blade bent, so it is useful only as my defacto SST now...
    Since you also probably don't have this SST in your toolbox, I suggest that you loosen the top nut 1/4 turn before removing the strut from the car. Don't loosen the nut too much though, because it is responsible for keeping the strut spring compressed. I did this before removing the LF strut and that procedure worked well.
    When it comes time to reinstall the new strut, tighten the nut as much as you can while holding the front coil spring seat upper with one hand. Then finish tightening that nut to 35 ft.-lb when the strut is installed in the car.
    The instructions suggest putting the removed strut into a large vise. I don't have a vise large enough to hold the strut, but it was not necessary.
    When I disassembled the RF strut, I found that it could be easily collapsed and stayed collapsed. Clearly all gas had leaked out of that strut. The LF strut showed more resistance to collapsing, however it was very slow to return to the fully extended position compared to the new strut. It was pretty clear that both struts needed to be retired.
    Here is a list of tools that you will need: 10, 12, 14, 17, and 19 mm sockets. 1/2" and 3/8" ratchet wrenches and torque wrenches along with various extensions.
    13/16" socket (or metric equivalent) to remove the tire lugnuts.
    MacPherson strut spring compressor. Don't buy or rent the cheapest compressor that you can find, especially do not use one that lacks safety pins to hold the compressor on the spring. Your personal safety is at risk and potential property damage may occur if the compressor flies off the spring. I am using the Sears Craftsman compressor, a photo is attached.
    1" box wrench to turn the Sears Craftsman MacPherson strut spring compressor.
    Photo 1 shows the spring compressor.
    2 - 4 show the new parts and part number labels.
    5 shows the top of the RF strut after the cowl assembly has been removed. Note the circular dust cover in the center of the strut top mount, use a small screwdriver to pry off.
    6 shows the old RF strut in place. Note the torn rubber boot. The leaked oil had dried, so that is not too visible.
    7 shows the front stabilizer link assembly, the front flexible brake hose, and the speed sensor wire harness removed from the strut.
    8 shows the bottom of the strut with the two nuts removed.
    9 shows the disc brake assembly with the strut removed.
    10 shows removed hardware from the strut, note the corrosion on one of the bottom bolts. This seems to be aluminum oxide from the wheel hub housing. I washed that bolt and most of the white powder came off.
    11 shows the old RF strut removed from the vehicle.
    12 shows my alternative to using a vise. The large screwdriver prevents the strut from rotating.
    13 shows the new RF strut installed.
    This is a fairly big job, plan to spend most of a day to account for learning curve. It's more important to do the job right than to do it fast, since you are working on the car's suspension and your personal safety is at risk. Wheel alignment camber will be affected by installation of the new struts, so for a complete job you should consider having the front suspension aligned after you've replaced the front struts.
    Note that safe disposal of the used struts requires you to drill a tiny hole into the strut body to vent out any pressurized nitrogen gas in the strut. As you compress the shock after drilling the hole, you'll see a stream of strut oil exit the hole. Have paper towels available to catch that stream.
    I understand that the dealer price for front strut replacement will be around $1K. If you take this on, then after you've done the job you can think about the $600 that you just saved. Good luck!
  2. vertex
    vertex Active Member
    671
    143
    new york
    2018 Prius Prime
    Thanks for the detailed info. I did this once years ago. I forget what kind of car. My spring tool (which I had used before) slipped, but somehow I did not get hurt. I decided I would not do it myself again. We have a Mavis service chain here, and they did it for $200 a strut on my old Focus. Not worth my trouble. When my Prius needs them, I will probably go there.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Cost me $1000 to have a local mechanic replace my struts...the majority of the cost being parts which ran close to $800 IIRC.
    Patrick's info here can save you a bundle, even if you can't/won't DIY.
  4. galaxee
    galaxee mostly benevolent
    9,810
    466
    MD
    the strut top is made of hardened steel. it's polished, not chromed. (fwiw)
    DH has been an undercar specialist about as long as he's been working on cars. he's found limited use for most of the SSTs, and this one mentioned in the manual looks about as useful as the rest.
    as long as the strut rod is fully extended into the strut mount, it won't turn. it's keyed to lock into the mount. if you push on the nut, you'll push the strut top down and it will spin. if you don't push on the nut and the rod stays up, it'll stay in place so you can turn the nut.
    a 1/4 turn on the nut- just to crack it loose- before removing the assembly is the most he would recommend. he wouldn't even do that in practice.
    Patrick, those spring compressors really are not the safest. DH won't be in the same 100-foot radius of a spring compressed with those. he used them before, has had colleagues use them before. they fail. catastrophe ensues. cinder-block walls get holes in them, floors get holes in them, in some cases skulls or other body parts get holes in them.
    now that he's got the garage set up, he's sending along a picture of what he uses:
    an alternative to doing the full replacement DIY is to remove the assemblies yourself, take them to a shop, and have them swap the struts out. then replace the assemblies in the car. that would be very reasonable in cost, maybe $20 per assembly. then you save the money in removal/replacement, and remove the element of danger to yourself.
  5. Patrick Wong
    18,200
    6,479
    Yes, when I was in graduate school 34 years ago, my roommate decided to replace the struts on his Mercury Capri (the car from Germany, not the rebadged Mustang.) I was helping him and he used a really cheap rented spring compressor that flew off and hit the garage wall.
    Hi Galaxee,
    Thanks to you and DH for your comments, and for pointing out that the rod is hardened steel. This must be why the visegrips could not bite in.
    I attached the exploded parts diagram to help our discussion. The "front coil spring seat upper" has the oblong hole that fits the top of the strut rod. That is the part that needs to be held in place when the top nut is removed. Of course, if the spring has not been compressed then spring tension will hold the spring seat in place so that the top nut can be removed.
    I agree that loosening the nut while the spring is under tension is a risky practice and accept DH's suggestion for a 1/4 turn as sufficient. Your suggestion to take the removed struts to a local garage for disassembly/reassembly also has merit.
    I felt that the Sears tool worked very well as it was easy to compress the Prius springs. I've used that tool eight times so far, having replaced all struts/shocks on my 2001 and 2004. Given the presence of the locking pins, it is not easy to visualize a failure that would result in the tool flying off.
    delosangeles likes this.
  6. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Nice. Having realized I never even talked about the suspension
    other than minor realignment, I've updated my 100K/part1 to point
    to this thread. I am thankful but baffled that I'm not having
    any issues with my own struts, and they even seem to still be
    absorbing shocks as they should.
    _H*
  7. galaxee
    9,810
    466
    MD
    DH has managed to replace a lot of struts without needing that SST. remove assy, compress spring, remove nut.
    he's going to go make some friends at the local dealer this week and take a look at it, since he's never actually used it.
  8. northwichita
    481
    102
    29
    Wichita KS
    Last time I did this on a previous car, I used the loan a tool from local Autozones to rent two sets of locking strut compressors to use on one strut at a time, this is the only way I would be comfortable changing struts.
    I'm surprised there is no special strut socket needed to keep the strut shaft from turning when the mount nut is removed, as here, the Bentley manual just describes holding the upper spring seat with the holding tool - picture here- SPX Toyota | Tool Detail -something that I would also improvise with.
  9. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    Great write up, Patrick.
    Worn out struts sounds like a good opportunity to go with the TRD Sportivo. If it's going to cost a certain amount anyway, the extra is much less than it would be otherwise.
  10. talonts
    talonts VFAQman
    448
    69
  11. Patrick Wong
    18,200
    6,479
    Thanks, Tom. Wait until Galaxee's DH sees the spring compressors you used... :eek:
  12. talonts
    talonts VFAQman
    448
    69
    Yeah, not the best, but the tensions here are surprisingly low - if I had had a 2nd person while doing the job, I wouldn't have needed the compressors at all - remove the top nut before jacking the car all the way up to remove the springs, and push HARD on the springs while a 2nd person starts the nut. I seem to remember actually getting the nut on the shaft on one of them when using the lowering springs, when I wasn't also trying to hold a camera at the same time.
    And the ones I had aren't really meant for daily usage like the HD ones with U-bolt clamps that most dealers use.
  13. The Critic
    The Critic Resident Critic
    3,193
    2,322
    CA
    Great guide, Patrick. What was the size of the two lower strut mounting bolts?
    I've replaced struts before on other cars, but not on the Prius specifically. Judging from your guide, it sounds like you did not have access to an impact wrench.
    With an impact wrench, I usually loosen the "big nut" (that holds down the strut mount) while the assembly is still mounted on the vehicle. It is a tad dangerous, but loosening it 1/2 turn or so hasn't given me any problems.
    Also, the SST really isn't necessary if you have an impact wrench. The power of the impact will allow you to loosen/tighten the nut without needing to hold down the center rod. I would also fully tighten the assembly before reinstalling it onto the vehicle.
    With an impact wrench, I have been able to replace four struts in about 1.5 hours, even for my first time. Two fronts can easily be done in under an hour. While I don't agree with Patrick that a strut replacement is a big job, it is definitely a job that should not be attempted unless you have the correct tools. As elitist as this may sound, I would not do this job if you do not have an impact wrench-- it's just too painfully slow and tiring.
    Also, the others have brought up an important point about spring compressors. This is what could happen if the spring compressor fails:
    (Fast forward to 1:09)
  14. patsparks
    10,664
    567
    Adelaide South Australia
    OMG, that was bad!!
    My left front strut was replaced under warranty, the other is fine.
    When it needs to be changed I will remove it and take it to my old employer's workshop to use their floor mounted hydraulic spring compressor.
  15. Patrick Wong
    18,200
    6,479
    A 19 mm deep socket is needed to remove the nuts that are attached to the lower mounting bolts.
    When changing Prius struts/shocks, some of the time needed is just to gain access to the top of the strut or the shock. To gain access to the front, you have to remove the cowl. To gain access to the rear, you have to remove most of the hatch trim.
    I agree that if you are equipped with a large air compressor, impact wrench, and a professional-grade spring compressor, that the job would go much faster. The point of my guide is to help shed light on what you can achieve, lacking those tools. The $ savings is sufficiently large so that I don't mind expending the time.
    It may be true that a professional mechanic could replace the front Prius struts in an hour. If so, it seems that the Toyota dealerships are pricing that hour of labor at ~$500-$600 or more.
    The video was very interesting. Although I can't tell for sure, it looks like the mechanic did not use a spring compressor for the sake of making an entertaining clip... I wonder if he was aiming the spring at the SUV in the parking lot...
    Prius_Angie likes this.
  16. patsparks
    10,664
    567
    Yes, the video was deliberate but I think they were surprised how much energy was in that spring, I know I was.
  17. mfa-prius
    mfa-prius Old member
    299
    45
    Hansville, WA
    Would it be practical to fabricate a tool that could be applied to the spring while it's on the vehicle (i.e., already compressed)? Then as the vehicle is jacked, the strut assembly could be taken out with the spring compressed, the strut replaced, the assembly put back in the vehicle, and the tool removed when the weight is back on the strut/spring.
    Feel free to tell me this is really stupid or there's no way it'll work. I haven't even had the tires off yet to have a good look at things down there. The "tool" I have in mind is a C-shaped piece of 1/2" - or-so steel, or a couple of links of hardened steel chain of appropriate size that a link (with one side cut open) would fit over the spring coil.
  18. Patrick Wong
    18,200
    6,479
    A reasonable idea.
    I think it would be pretty difficult for you to install such a tool while the car is on the ground and the spring is compressed, just because there isn't much clearance in the wheel well.
    It really isn't very hard to compress the spring when the strut is removed from the car because the Prius springs are not particularly robust. Tom in post #12 above previously made the point that he could compress the spring the needed amount by hand. I'm a smaller guy than he is, and like to let my tools work for me, but I agree that not that much compression is needed.
    If you have a decent spring compressor (of at least the quality that I used, if not better) then you should be fine.
  19. mfa-prius
    299
    45
    Hansville, WA
    Thanks; I looked, and you're right. There isn't much clearance anywhere on the Prius. I've been browsing through the rapair manual, and am astounded at the complexity of the thing.
    Will Champion Toyota help with part numbers over the phone, since they seem to be unavailable on the Web?
    Finally (for now), most parts lists I've seen show 2 sets of part numbers for front struts -- "to 3/05" and "from 04/05". What's the difference? Some say the 4/05+ parts are equivalent to the 2006+ touring suspension struts (http://priuschat.com/forums/gen-ii-prius-modifications/65451-why-did-toyota-change-front-struts-in-2005-a.html#post905729), but other threads say the touring suspension front struts are no different than standard (e.g., http://priuschat.com/forums/gen-ii-...e-vs-touring-edition-dirty-little-secret.html). Bottom line: which set of struts should I order? :confused:
  20. Patrick Wong
    18,200
    6,479
    Just decide which Toyota dealer you wish to purchase from; then provide your model year and VIN and let the parts dept decide what you need.
