Hit a curb going straight on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rachael71, Dec 10, 2016.
  1. Rachael71
    Rachael71 Member
    50
    28
    Iowa
    So, there was a winter storm today and it was snowing heavily. It was the first time I've driven my car in snow and I managed to screw it up pretty good. I was heading to a T intersection with stop signs and I started sliding when I applied the brakes. There were cars everwhere, but I managed to swerve to avoid them. I thought the tail would whip out and I'd end up sideways. Oh no, the traction control came on and I glided fairly straight into a curb. Strangely the car made no noise as I hit the curb and went on to the sidewalk-but when I came back onto the street I heard a thunk as I came back down. I pulled over, inspected the car. Nothing, nothing at all- so I carried on my way going very slowly, of course. When I pulled into a UPS store to drop off a package- I noticed almost all my front lights are now out. I've only got lights on the drivers side and it's the side light not the main light. Did I knock out all my lights during this incident? it seems crazy to me.
  2. saltdiscus
    saltdiscus Member
    198
    89
    US
    I too had similar accident recently but luckily only my tire went flat with splash guard out of its place.My guess is you might broken the light harness wire .Can you pop up your engine and check the top and bottom to see anything out of its place.
    Rachael71 likes this.
  3. Rachael71
    Rachael71 Member
    50
    28
    Iowa
    If it's broken, I'll need to get a new one right? well, it's dark and snowing out so I'll probably wait till tomorrow to look at it, especially since I can't really do much about it at the moment.
  4. saltdiscus
    saltdiscus Member
    198
    89
    US
    Yeah we can't tell you anything before seeing the pic of damaged parts .I would defiantly look at junkyard before buying new one.I hope your headlight housing is fine because that will cost a lot than some wires.
    #4 saltdiscus, Dec 10, 2016
  5. Rachael71
    Rachael71 Member
    50
    28
    Iowa
    how would hopping a curb cause this to happen? just wondering, I've never heard of such a thing.
  6. saltdiscus
    saltdiscus Member
    198
    89
    US
    Hmmm my guess is some wire went out or even simple as fuse went out .
    Does your monitor show any error?
  7. Rachael71
    Rachael71 Member
    50
    28
    Iowa
    No, it shows nothing. The car drove fine as well
  8. bisco
    51,143
    perhaps the impact jarred something loose.
  9. saltdiscus
    saltdiscus Member
    198
    89
    US
    Do you have multimeter to check headlight bulb continuity .After that we will know something?
  10. Rachael71
    Rachael71 Member
    50
    28
    Iowa
    I don't have one of those. Maybe I'll pop over to Autozone tomorrow and see if I can borrow their's
  11. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
    Rachel,
    Most likely thing is you popped some connector out or something, as others have said. It's also possible that you might have simply broke a lightbulb.
    The thump when you backed off the curb, weirdly enough, is normal for a Prius. Low ground clearance; I get that backing out of the garage, sometimes.
    I've had cars where connectors popped off. Me, I'd snag my downloaded copy of the Prius troubleshooting manual, grab my volt/ohm/milliammeter, check the fuses and start tracing wires. But I'm a EE. And it's wintertime.. So maybe I'd just take the car to a trusted mechanic with access to all those things and let him/her do it.
    The dealership will be happy to chase it down, as would any local body shop, but they'll charge you hourly rates.
    KBeck
  12. Rachael71
    Rachael71 Member
    50
    28
    Iowa
    Well, i went to Toyota today and two bulbs needed replacing-33 dollars- no charge for labor. Whew! Yeah, I went to Autozone and they just said forget using a multimeter- I'd need to get underneath the car to do that! I should mention I was at a corner when I hit the curb, so I drove onto the curb and then I just kept going and left the curb on the next street travelling about 25 feet- I came off the curb going forward, not backwards.
  13. bisco
    51,143
    congrats, thanks for the update.(y)
  14. working1
    working1 Active Member
    121
    111
    Glad everything worked out and most importantly no one was injured. I'm assuming your car does not have snow tires. So, a friendly suggestion is to consider installing snow tires for winter driving. It may or may not have made a difference in this case. This in my second Wisconsin winter with a set of Michelin X-Ice tires and will never drive another winter without them.
    Rachael71 and Mendel Leisk like this.
  15. Mendel Leisk
    40,576
    ^ This.
    Christmas eve we did a drive around, looking at the lights. Up the hill from us the temp drops a couple of degrees (Centigrade) and the snow depth increased by at least 6". Everyones' driveways are flanked by mountains of snow. We stopped to take pics at one spot and I noticed the roads were bare, but slick.
    Anyway, on the way back down, I totally missed spotting an upcoming four-way stop. My wife and son both went into alarm mode, I tromped the brakes, and came to a nice controlled stop, ALB barely kicked in. This is with Michelin X-Ice, purchased/installed right after getting the car.
    They can't perform miracles, but the softer rubber and aggressive tread will definitely improve your cold weather traction.
