Hit a deer
Discussion in 'Gen 2 Prius Main Forum' started by mountainsean, Jun 14, 2007.
  1. mountainsean
    mountainsean New Member
    The other night I was on the way home doing about 50 mph and there was a dead deer in the road. I hit it square on - both front tires and both rear tires ran right over it. The bump wasn't as bad as I anticipated - I was expecting it'd feel like hitting a pothole, but it was "softer". Still, by the time I got home and slowed down, a really yucky smell crept into the cabin (think burnt hair, now think burnt hair + burnt venison). I got out a flashlight and looked under the car, and it was pretty gross. Disgusting really. Anyway, I hosed it all down the next day and ran it through a carwash, and the smell is better but not gone completely. I don't see any leaks under the car. There's still some hair and (eeew) guts stuck to some of the bits underneath. Is there anything specifically I should be concerned with or look for? Worth taking it in to a mechanic? Seems to ride just fine, no alignment or suspension probs that I can tell.
    The only weirdness is that the CVT seems to stay revving high even after I let off gas sometimes. Maybe it's always done that and I'm just now noticing? MFD shows 53 mpg and hasn't dropped since the incident.
    Should I chalk it up to luck and be on my way?
    -Sean
  2. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    I've no clue, but after an incident like that there very well could be unseen damage. If you're noticing a difference in the motor sounds, you probably would be safe having it checked out at your local dealer. Good luck, you fared better than the deer. :huh:
