Hit a Raccoon now this is hanging what is it?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by heyphillip, Jan 22, 2017.
  1. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
    1485087210389.jpg Resulting in $987 worth of damage. The problem is my Prius isn't going into the body shop until 2-19-2017 due to the shop being back logged with appointments. The only thing I'm concerned with is this falling off completely while driving.
    MrMischief likes this.
  2. saltdiscus
    saltdiscus Member
    198
    89
    US
    Looks like the front splash gaurd.I think there are 4 screw holding it.
  3. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
    The middle screws are loose only tight screw holding it in place is the screw on the passenger side when facing the front of the car to the bottom left.
    51,155
    try to wire tie it up until you get it fixed. shouldn't be too hard.
  5. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
  6. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    $987? What other damage was done?
    Splash guard is simply held by bolts and push fasteners.
    I've even have a few zip ties on mine
  7. Kenny94945
    Kenny94945 Active Member
    843
    418
    Sausalito
    2016 Prius v wagon
    From the photos as mentioned above, the only item I see as possibly failing off is the lower air dam.
    Yes zip ties are a very easy way to secure.
    That air dam directs air around the car so I temporary repair will cause no harm IMO.
    $1000 in damage...parts, paint and labor add up.
    Lastly, I think the OP meant to write a Raccoon hit him. :)
    Good luck.
  8. Mendel Leisk
    40,584
    The black underpanel is one of these:
    You're likely missing a few fasteners too. With a few tools you can remove it relatively easy, without even raising the front. Check with a dealership parts department and they should be able to sort out what you need.
    With the front end raised and that above piece removed, you might be able to bring that crack in the front bumper back together, and bond it with a bumper repair kit, applied on the back. One that uses a strong two-part adhesive/filler and fiberglass mesh. A body shop could probably help you out with that, and do it very seamlessly.
  9. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
  10. heyphillip
    heyphillip Member
    131
    47
    Maple Shade NJ
  11. Mendel Leisk
    40,584
    Ever wonder why they call them "bumpers", lol. Yeah I would just repair, but that's me. There's a simple crack that could be reinforced from behind. The black piece under is maybe salvageable, just needs a few replacement fasteners. Ours was getting a little knackered from running over curbs, and snagging as it pulled back off. I took it off and fixed up with some two-part epoxy and fiberglass mesh. Or hey, for an edgy look, something like this:
    A bumper with moxie | PriusChat
    BTW, would you say we have a consensus, that Apple, Samsung, Microsoft et al: should take a break from whatever and fix this image rotation thing? I used to reliably and monotonously import iPhone images to my pc in Windows 7, just plugging in my phone, right-clicking it's icon and saying copy over the images, correct orientation as needed, delete the originals. Now, after the "upgrade" to Win10, it's completely broken. I've cobbled a totally manual method, and need a third-party program to fix rotation after import. It still doesn't work on videos, though.
  12. ETC(SS)
    6,958
  13. Mendel Leisk
    40,584
    The good 'ol days.
    Raytheeagle and Bluegrassman like this.
  14. Mendel Leisk
    40,584
    You know: a few holes drilled, one or two white zip tie cross-cross stitches, refurb the black underpiece and pick up the missing fasteners at parts dept: where's the harm? It's down low, not that noticeable. Keeps a great honking piece of plastic out of a landfill too.
  15. milkman44
    milkman44 Active Member
    591
    386
    Ky
  16. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    I was told on my 2011 that the chips in the front bumper were so bad that the body shop would charge me the same price for a new bumper painted as fixing the old one. So that estimate doesn't surprise me.
  17. Mendel Leisk
    40,584
    This worked for me, patching up a Civic bumper, had a chunk knocked (cleanly) out. They'd rolled up to a parking stall concrete wheel stop, the kind with rebar nailing it to the ground. Only this one had the rebar sticking up about 5".
    A simple crack, would be simple to repair. And with a can of Dupli-Color, it'd be close to seamless, especially down so low.
