hit and run with 800 miles, pissed
Discussion in 'Prime Main Forum (2017-2022)' started by Joeteck, Apr 6, 2019.
  1. Joeteck
    Joeteck Junior Member
    43
    Long Island, NY
    2018 Prius Prime
    I am pissed. Came out and found this.
    Hit and run in the Seaford parking lot at stop and shop
  2. Marine Ray
    Marine Ray Senior Member
    1,139
    949
    Sparks, NV
    That sucks.
  3. citiprius
    citiprius Active Member
    241
    238
    51
    2018 Prius Prime
    It's bad bad bad....Is the fender/bumper ok? The replacement parts for the signal module should be around $250, but you can replace it yourself to save some money. Or, would you rather pay deductible, have a Carfax report and increase in insurance premium?
    The replacement should take less than an hour. I've done the DRL mod for 5 hours on both side, most of the time spent on adding the LED inside the module. Removing / installing that module is relatively easy, especially on the driver side as it has more rooms. Check out the sticky thread under the modification forum, that really helps. Good luck.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Exactly what I was going to say!
  5. bisco
    52,695
    bummer! can you get a pic from a little further out?
  6. Joeteck
    43
    Long Island, NY
    2018 Prius Prime
    I was going to do it through the dealer. Buy the part and have them do it.
    I cant figure out if its access through the wheel well or the truck.
  7. will the engineer
    will the engineer Active Member
    238
    119
    LA
    2019 Prius Prime
    Jesus on a cracker!
    And there I was with my first world problems complaining about how I got all these rock chips within 1st month of ownership
  8. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    No respect out there anymore.
  9. citiprius
    241
    238
    51
    2018 Prius Prime
    LOL
    It should be accessed from the bottom of the vehicle. Simply jet up the front wheels, remove the bolts that hold bottom black plastic cover at the bottom of the fender (6 or 7 screws? one of them also holds the LED module), then unplug the wires harness and remove the other 2 screws that hold the LED module (you can't see the top one but you can use your hand to touch it) with a super short phillips screw driver. Remove the plastic triangle black panel right next to the LED module in front by just popping it off. Then gentling push the LED module back and slide it down. Pulling the fender out a bit (it's plastic so can bend a bit) will help.
    Joeteck likes this.
  10. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Sadly, I'm not sure the "anymore" part is pertinent. People have been looking to see if anyone saw the deed and head out ASAP for a long time.
  11. smyles
    smyles Active Member
    332
    229
    US
    2020 Prius Prime
    I don't think it's just respect. Nowadays every single car part is $$$ and on top of it every driver thinks they drive an equivalent of a collectable Ferrari, so even a bumper scratch or a door ding result in such a hassle that it overcomes whatever decency one might have.
