Hitch Mount Bike Rack Suspenders
Discussion in 'Gen 2 Prius Accessories & Modifications' started by gordonr, Oct 14, 2006.
  1. gordonr
    gordonr Member
    117
    Massachusetts
    In a prior topic there was a discussion about the viability of carrying more than 2 bicycles on a hitch mount carrier. It seems the general conclusion was that it was problematic with the Coastal hitch bending a bit too much for people's comfort. It doesn't seem to be related to receiver size either (1.25" vs 2.0"). One person had the idea to mount the carrier closer to the car by making a new hole in the receiver section of the carrier to mount the rack closer to the car. I've been thinking about this problem and have taken some pictures which mock-up an alternate solution. I'll call them bicycle carrier suspenders. There are two variations of this idea for different types of racks. I have not decided to go ahead and make one of these for myself as I first wanted critical feedback on what engineers out there think of the idea.
    Here it goes...
    The basic component of the suspenders are glass hatch clips made for fitting trunk mount bike racks on certain cars. Yakima, Thule and others make these. Here is an example of the Yakima version...
    [attachmentid=5290]
    In their intended usage they are placed inside the car at the top of the hatch with the strap going outside...
    [attachmentid=5291]
    Instead of holding on a trunk rack, I see them being used on a typical hanging style hitch bike carrier. The picture below shows a mockup of how they would work with a Yakima Kingpin 4, but the same idea should work with any rack of this style. In a "final" version I'd make some custom straps with cam buckles rather than the tied-on straps used in the mockup. The idea is that the straps add some support so the hitch isn't carrying the entire load. The rack shown is a borrowed one, and this isn't a solution that really works well for me as I need to carry two adult bikes and two 20" kids bikes. Getting two 20" kids bikes to fit on this style rack is a nightmare and isn't user friendly. Nevertheless, this may be a great solution for others. The big negative is that you need to undo the straps to get in the hatch.
    [attachmentid=5292]
    Since I use a tray style carrier from 1upusa, I've thought of an alternative using these same straps. It involves placing the straps at the bottom of the hatch like this...
    [attachmentid=5293]
    From the inside of the car with the hatch closed it would look like this...
    [attachmentid=5294]
    The suspenders would then lend support to the rack (which can be expanded to carry up to 4 bikes) like this (again with a custom strap and buckle arrangement, but for the mock-up you get the idea)...
    [attachmentid=5295]
    I can see the need to protect the bumper in some way. I also wonder if the force of the strap on the hatch might tend to do something bad over time. The hinge point of the hatch (where the solution above is mounted) is no doubt stronger than the latch point on the bottom.
    It goes without saying that you'd never get Yakima, Thule, Saris or any retailer to "approve" of either of these setups. The only piece of supporting data is that Yakima (and probably Thule & Saris) rate their trunk style rack for the Prius to hold up to 3 bikes or 90 lbs. It doesn't seem like a huge stretch to think that straps and a hitch mount should be able to handle 4 bikes plus the weight of the rack. With that said, anyone who tries either of these ideas are still on our own.
    What do people think of this idea?
  2. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    :D Great idea!! Now I can feel better about getting the Coastal 2 inch receiver again.
    Wayne
  3. gordonr
    gordonr Member
    117
    Massachusetts
    For what it's worth as this seemed to be of little interest...
    After playing around with the various options I decided that making the hanging style hitch mount bicycle rack work for me was the best option for carrying 4 bicycles with the greatest sense of safety. Compared to the tray style I've used for two bikes, this system takes longer to setup and load and offers no easy access to the hatch once the bikes are loaded and suspenders in place (although the hatch does clear the rack without the straps in place). The bikes also sit quite a bit higher than the tray style and as such completely block the rear view and affect wind resistance to a greater extent.
    On the plus side, after a couple of trips including short highway sections, speed bumps and country roads it appears very stable and I'm not worried about littering the roads with fallen bikes or bent/overstressed hitch receivers. With that limited experience I decided to buy the Yakima Kingpin during the recent sale REI had on Yakima.
    To make the "final" suspenders I got a pair of 2' straps from NRS and sewed the free end into a loop. To keep things tidy I also sewed on some Velcro (male/female back-to-back) to secure the loose end of the suspenders so they don't flap in the wind. Total cost of the suspenders was $16.00 for the Yakima glass hatch hooks plus $5.70 for the straps and $0.50 for the Velcro.
    [attachmentid=5455]
    [attachmentid=5456]
    [attachmentid=5457]
    [attachmentid=5458]
  4. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    It looks like a good setup - would have helped me a few weeks ago... Flew down to new mexico to meet up with a bunch of old friends, we rented some bikes and a big SUV to go up into the mountains for the weekend, and the rack we had for the bikes wasn't very stable at all... the worst part - we put the straps on, and then started loading up the bikes. the metal frame where the straps hooked onto the rear door litterally started bending!
  5. cobra94563
    cobra94563 Junior Member
    48
    Nice solution...thanks for sharing.
  6. john1701a
    john1701a Prius Guru
    12,760
    5,245
    57
    Actually, you don't have to breach the water seal.
    On my 200-mile trips with the bikes using a strap-on rack, I've reinforced them by tying a rope to the welded hinge connection for the hatch itself.
    Sorry, but there's no picture of that... just a text mention in the USER-GUIDE. I hadn't realized there was that much interest.
  7. FireEngineer
    1,247
    124
    Well John show us a picture, I know you've got one somewhere.
    Wayne
  8. gordonr
    gordonr Member
    117
    Massachusetts
    The following goes into the ultra-nerd category...
    The notion about carrying more than two bikes on a hitch receiver bike rack has gotten the better of me. Yes, I believe the suspenders work just fine, but I've been curious about whether they are really needed or if I was just being overly conservative.
    Yesterday I decided to play around with some physics modeling software (i.e. interactive physics 2005) to try and understand the forces being placed on the hitch receiver. The following diagram shows the forces at play on the hitch for 1, 2, 3 and 4 bikes on a hanging style rack. The rack is modeled after the Yakima Kingpin in a simplifed way. In the model the rack is assumed to weigh 35 lbs and each bike (represented by the yellow disks) is 25 lbs. The model simulates what forces would be present if you just placed the rack in the receiver without being screwed in place. In reality this isn't what happens, but this method kind of relates to tongue weight limits.
    [attachmentid=5538]
    It's interesting that 1 and 2 bikes stay within (or very close to) the 200 lb tongue weight limit of the Prius hitches, and 3 and 4 bikes appear not OK. This also approximates people's observations.
    The next diagram models the alternate technique where you mount the rack deeper in the receiver so it's closer to the car. This model was only done for 4 bikes. Moving it in 3" has a significant impact, but it seems like you need to move it in more to get under that 200 lb figure.
    [attachmentid=5539]
    Anyways, it was a fun exercise to do. The software makes physics fun.
  9. mtsarpilot
    mtsarpilot Junior Member
    87
    Now that's a creative program. I'm going to have to give the physics of that some thought. I've been carrying 2 bikes no problem, but noticed when I put the weight of 4 bikes on the rack, the rear end of the car sagged enough that I was concerned about wheel well clearance to the tires. Is the 200 lb tongue weight limitation a limit on how much weight should be slung off that back of a Prius, or the limit on what the Coastal Hitch can take before bending to much? That limit was stated by Coastal not Toyota.
    As for stabilizing the rack to avoid the Coastal Hitch bending, I solved it by beefing up the hitch. Check out the solution posted at: http://priuschat.com/Solved-the-Coastal-Hi...lem-t25807.html
    The straps are a nice approach, but you do lose access to the back of your car. By beefing up the hitch so the load is transmitted to the car frame as the hitch should do, the problem goes away and you get full access and no hassle with straps each time you load/unload the rack. The downside is the cost was a good bit more than the straps :( I use the rack a lot, and want to get into the back of the car, so to me the extra cost was an acceptable tradeoff. I plan to have the Prius for a long time and use the rack a lot, so the cost will amortize out to almost nothing.
    If I have an accident and total the car I'm going to want to get this hitch back for my replacement Prius. As long as the accident is not from the rear that is. If that happens I figure the hitch is toast and it will rip the heck out of the car's frame.
    That leads to an interesting question. The Prius was not designed to carry a hitch. With one on the car, in the event of a rear end accident the dynamics of the crumple will be altered. Some of the load will be transferred further into the frame. Will the hitch bend, the bolts snap, the frame bend differently, will it matter? Given what I have done (see pictures in referenced post) it will certainly carry some of the force to the jackpoint pillar I mounted to. That will probably bend forward like paper as it is structurally solid vertically but not in a forward force. I wonder what this will all do to the frame.
  10. gordonr
    gordonr Member
    117
    Massachusetts
    <div class='quotetop'>QUOTE(mtsarpilot @ Oct 31 2006, 11:11 AM) [snapback]341199[/snapback]</div>
    The SAE defines the specification for hitch classes which includes tongue weight. I believe tongue weight is nothing more than the force pushing vertically on the ball when towing. If you placed the load where it hooks to the receiver on a bathroom scale it would give you this measurement. As the simulation above shows, you can't just add up the weight of the bikes and rack and relate that directly to tongue weight. It's more complex and relates to the distribution of the load on the rack and the nature of the more complex lever arm holding the bikes (i.e. the rack). The simulation does jive with the general wisdom that to carry 4 bikes you need a Class III hitch (500 lb tongue weight). Given how Coastal seems to operate, I believe the 200 lb tongue weight limit is a somewhat casual specification that typically relates to Class I hitches. I'd like to believe Coastal did an actual design analysis and field test to prove that the hitch meets Class I specs (atleast with regard to tongue weight), but I have doubts. I'd have more trust that Curt did actual engineering work on their design, but they don't offer a 2" option. To your direct question, given that Toyota doesn't approve of any of this (towing or hitch mount bike racks), I'd guess the 200 lb limit is more what the hitch can withstand with acceptable bending rather than what the car can take. Clearly Toyota would wash their hands of all of this if any problem happened either during an accident or structural issues from everyday use. For that matter I don't remember seeing any written information saying that Coastal hitch meets any "Class" spec. The 200 lb limit appears to be more anecdotal or based on conversations with Coastal.
    Thanks for the reference to your solution. That looks wonderful! Very cleaver solution! $120 seems to be a fair price for that amount of custom work. I do share your concern about what hitches and what your modification in particular may do to the structure during an accident. Where do the HV batteries sit relative to the central rear jack point?
  11. Norm611
    Norm611 Junior Member
    45
    Western New York
  12. paul2102
    paul2102 Junior Member
    28
    I just read through this thread.
    The way I under stand it, tongue weight is actually the weight on the ball of a hitch, not the hitch receiver. So the weight of the bike rack and the bikes, at a point where a trailer would connect to the ball of the hitch, if there was one there, is where the weight measurement should be taken. Which is basically the total weight of the rack and the bikes. Not to exceed 200 lbs. for a class I hitch.
  13. tombellanca
    tombellanca New Member
    53
    Encinitas, CA
    Anyone have any idea how to find this topic/discussion?
    I'd like to beef up my coastal hitch.
    What type of shop should I go to - auto body?
  14. tombellanca
    53
    Encinitas, CA
  15. Mike_10
    Mike_10 Member
    73
    Boston MA
