Hitting 200,000 miles soon, Need Inventory of Repairs
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by saechaka, Jul 21, 2010.
  1. saechaka
    saechaka Member
    225
    I've had my 2005 prius since day one, and I'm at 196k miles and need a list of all the things I will need repaired/replaced.
    In addition to basic oil changes, filter replacements, these are the repairs I have done.
    • Changed radiator fluid around 80k
    • replaced front brakes around 100k
    • had brake actuator replaced
    • water pump replaced around 90k
    • changed spark plugs around 120k
    • Changed psd fluid around 60k and 120k
    As you can see, I am in need of some major repair/replacements and I will be calling around to the local dealerships to start getting estimates. Any help getting a list would be appreciated.
  2. Patrick Wong
    18,200
    6,493
    Both the engine and inverter coolants are supposed to be replaced at 50K mile intervals, after the initial change was performed. I do not recommend neglecting that as overheating is a great way to induce failure of the normally reliable engine and inverter.
    I am sure that your front struts and rear shocks are totally dead if they had not previously been replaced, and suggest you have those done now.
    In addition the serpentine drive belt, engine coolant thermostat and PCV valve should be replaced.
    The front and rear brakes should be inspected, maybe they are due for replacement now.
    The transaxle ATF needs to be done again.
    You might consider replacing the 12V battery and inverter coolant pump as preventive moves since those were not on your list of prior repairs.
    Check your tire tread depth and windshield wiper blade effectiveness, and replace as appropriate.
    Finally, look at the 120K mile scheduled maintenance list, and have those items done.
  3. saechaka
    saechaka Member
    225
    Thanks. I'll begin calling around for quotes.
  4. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    It would be a good idea to flush your brake system with new brake fluid too.
  5. saechaka
    saechaka Member
    225
    If I get new rear brakes will they flush the system or are those two seperate services?
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Unless you pay for a brake fluid change or flush, you will most likely only get enough of a brake bleed job to get the air out of the rear brake circuit.
  7. Patrick Wong
    18,200
    6,493
    Replacing brake fluid would be a separate service. When the front brake pads and rear brake shoes are replaced, there's no need to mess with the hydraulic fluid (other than to possibly remove some fluid from the brake fluid reservoir if the level gets too high as the front caliper pistons are retracted to make room for new pads.)
  8. saechaka
    saechaka Member
    225
    Ok. I have a feeling this major repair will cost close to $3000. Thanks. One more added to my list.
  9. joe350gt
    joe350gt It's too windy here...
    40
    38
    Wichita, Ks.
    What a timely thread!! I'm at 195K on my '05 and am looking at some of the same services. Thanks Patrick for the ideas on what I need to add to my list. PC never ceases to amaze me with the info and help here!!
    I'm doing CVT and inverter fluid (last done at 150K), plugs (done at 106K), my struts and shocks are original too so I guess they're used up...lol..!! Will have them check the brake pads (original!). Good idea on the belt/PCV/thermostat, I had the radiator drained/filled at 75/150K, how often should engine coolant be done? Also had brake fluid flush/fill done once and have an Optima yellow top I put in last October just for the fun of it!!
    What will they hit me for to replace the invertor coolant pump at the same time? probably should since the fluid would be in the change process. The $$ are piling up lol!!
    Joe
  10. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    My first major maintenance coming up at 125k is estimated at $224 so far. All of it is DIY, and no one would mistake me for being mechanically inclined.
  11. Patrick Wong
    18,200
    6,493
    Replacing the front struts and rear shocks alone, will probably cost you $2K. :eek: (That is one reason why I DIY.)
    http://priuschat.com/forums/gen-ii-...ts-regarding-replacement-2g-front-struts.html
    http://priuschat.com/forums/gen-ii-...oubleshooting/74531-replaced-rear-shocks.html
    The engine and inverter coolant should be replaced at 50K mile intervals after the factory-fill coolant is replaced at 100K miles.
    My guess is that you will probably be charged around $400 to replace the inverter coolant pump. (Another reason to DIY since MSRP is $116, I paid $88.)
    http://priuschat.com/forums/gen-ii-.../65173-how-replace-inverter-coolant-pump.html
  12. saechaka
    saechaka Member
    225
    Thanks for pointing out that thread. I've been crossing my fingers hoping to do all my major service repairs after 200k because I can get an extra 15% off the service. Would changing the inveter coolant pump be the best DIY service in terms of ease and money saved?
  13. Patrick Wong
    18,200
    6,493
    Probably, that is not hard to do and if you gain a sense of accomplishment from that project, that might encourage you to perform other maintenance tasks as well. Good luck.
  14. saechaka
    saechaka Member
    225
    One more thing, should I replace the water pump as a preventative measure? I had to replace it at 90k so I think it should be due.
  15. Patrick Wong
    18,200
    6,493
    Are you referring to the engine coolant pump that is powered by the serpentine belt? If yes, then I would say that it would be OK to replace it as a preventive move if you want. I would definitely replace the serpentine belt now, as a minimum.
    You'll have some advance notice of a pending engine coolant pump failure when you see coolant start to weep from the bearing. So, if you make it a habit to check your engine oil from time to time while you are pumping gas, you can also take a look at the engine coolant pump and plan to change it soon, if you see a pinkish or whitish coolant stain appear on the inside of the pump pulley.
  16. saechaka
    saechaka Member
    225
    Here's the quote. Please let me know if I'm missing anything or need to add anything. Thanks.
    Water pump- $415.00
    Inverter coolant pump- $260.00
    Serpentine belt- $25.00 (included with water pump labor)
    Thermostat- $125.00
    PCV- $132.00
    Coolant flow valve- $325.00
    Shop supplies for misc. items- $20.00
    Tax- $117.18
    TOTAL- $1419.18
  17. Patrick Wong
    18,200
    6,493
    A good start. How about replacing the transaxle ATF fluid?
    Did you decide to defer replacing the front struts and rear shocks?
  18. saechaka
    saechaka Member
    225
    I'm going to defer struts as that is too expensive. I mentioned transaxle ATF fluid but he said there is no such service. I recall it being referred to PSD fluid change. Do you happen to know of the official service title for transaxle ATF fluid? Or should I just find another dealer that knows the name as they are more competent to perform the service? I had to drive my car to Olympia, WA to have it changed previously.
  19. Patrick Wong
    18,200
    6,493
    Well, the Prius has a transaxle, which can be easily demonstrated by looking under the bottom of the engine compartment. That transaxle has fluid within, which is 4 US quarts of ATF WS. The fluid does deteriorate after a reasonable number of miles have been logged.
    All that the service tech needs to do is drain and replace the fluid. Maybe the service writer doesn't understand that, but I am sure that the tech with Prius training does.
    See if the service writer can understand this; if not maybe you'll have to visit Olympia, WA again.
  20. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Hi saechaka, you mentioned previously about saving money with some DIY. In my opinion changing the ATF is a really good simple DIY job. Several people have posted info/guides here if you search for it and it looks pretty easy. I've actually just bought the fluid and a long funnel and will be changing mine for the first time in a few weeks (at 60k miles). Just make sure you use the genuine Toyota fluid (ATF - WS) as it MUST be compatable with the (very expensive) electrics contained the the transmission.
