Hitting noise coming from back seat area, when start the car. 23 prius
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by priusasa, Aug 23, 2025 at 5:53 PM.
  1. priusasa
    priusasa Junior Member
    50
    2023 Prius
    Before I go to dealer, I wanted to write here.
    When you start the car, I hear this noise. First, it's like a buzzing sound, not from the brake actuator. But like some motor is engaging. (around 1 second)
    Right after I hear "tık tık tık tık tık" sound, then it stops. It's like it's trying to do something but it can't.
    That sound coming from back seat area.
    When I turn on the car and run back to trunk and listen, I don't hear much. So it's not coming from trunk. It's somewhere in the back seat.
    Usually it's coming when car sits longer time before I start.
    Maybe from fuel pump? Or some doors for fan in the back seat? Not sure. Do you hear something like this?
    I will go to dealer but I am sure they won't diagnose and won't care because it doesn't come every time and needs effort to hear.
    51,340
    can you post a recording?
  3. priusasa
    50
    2023 Prius
    I will try. Its low sound but I will try to record. I know its difficult to understand if you dont have the same noise. But that also means its not normal and something is wrong with my car
  4. BiomedO1
    BiomedO1 Senior Member
    2,966
    1,580
    SacTown, Ca
    There's the fuel pump, Evap, and traction pack cooling fan back there.
  5. Tande
    Tande Active Member
    532
    314
    Mich.
    Electric "E" brake releasing......maybe? .....
