Hmmmm I don't have a key to my 5 month old Prius
Discussion in 'Gen 3 Prius Main Forum' started by Halcyon24, Feb 25, 2015.
  1. Halcyon24
    Halcyon24 Junior Member
    34
    Fort Pierce, Fl
    okay that was embarrassing.
    #1 Halcyon24, Feb 25, 2015
  2. Dave14Prius
    Dave14Prius Member
    72
    26
    NE Missouri
    It is in your fob.
  3. Halcyon24
    34
    Fort Pierce, Fl
    yea. i just deleted my post due to shame. lol. owned the car for 6 months and never knew that.
  4. matt b.
    matt b. Member
    251
    60
    L.A.
    look on the left corner and you'll see where it says "push" push it in and the key will extracted it's self from the Bottom. when you look at the bottom of the unit there's a slot for a key ring that's your key once you pull it out
  5. Dave14Prius
    Dave14Prius Member
    72
    26
    NE Missouri
    No need to be embarrassed, salesman did not show you and you have not read your manual.
  6. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    You should also find that after you take the key out, you can put just the end of it in the slot and twist it to separate the two halves of the fob. This gives you access to put in a new battery when it's needed.
