hole in carpet under driver seat, bolt through the floor
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pasadena_commut, Jan 28, 2021.
  1. pasadena_commut
    pasadena_commut Senior Member
    1,482
    445
    Southern California
    The car came back from having its stolen cat replaced a few days ago. Today when moving my junk back into it I noticed a hole cut in the carpet under the driver's seat. The flap of carpet is still there, with a few inches of insulation removed, and there is the head of a pretty substantial bolt, which goes through the floor. The bolt is close to the center of the seat and about four inches forward from the back end of the rails. I did have a cat shield installed while they were at it, but that doesn't extend back quite that far, and none of the connectors holding that are anywhere near that size.
    I don't recall seeing that cut in the carpet before, but it is under the seat, so I could easily have missed it.
    What is it for?
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    I have no bolt like that on my 07. Its all flat under the seat. Pictures please.
    Jack up the car a little on that side and look under that car. Maybe they got carried away with the car shield and now its a seat shield too.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    You need to find out because the CAT itself can get VERY HOT and if that bolt is connected directly to the CAT or the pipes immediately before or behind it, this could end up being a BIG problem......as your carpet smolders and smokes. :eek:
  4. pasadena_commut
    1,482
    445
    Southern California
    There is also one under the front passenger seat in the same position (measured from the front or midline of car.) It is posterior to the back edge of the shield and nowhere near the cat itself. The one on the driver's side seems to be above a white plastic conduit which runs front to back. It is roughly over what appears to be a square access plug (see attached). The one on the passenger side seems to over some black plastic. I don't feel the bottom of either screw, both seem to be under plastic. The bolts are 12mm. In both cases the carpet was cut, and a chunk of insulation removed, to expose the bolt.
    If you press on the carpet in that area can you feel the head of the bolt?
  5. edthefox5
    10,096
    4,805
    Clearwater, Florida
    Well that's not a big protruding bolt dude....its a bolt head...
  6. bisco
    49,447
    looks like a cat shield install to me, have you asked them?
  7. pasadena_commut
    1,482
    445
    Southern California
    The car did just have a cat shield installed but that is fastened on by small security head fasteners tips facing up, a few at the front, and a row on each side. The shield itself ends quite a way forwards of where these bolts are located.
    On the other hand, the service department did replace the stolen catalytic converter at the same time. Perhaps these held on something on each side which needed to be dropped to put the new cat in? Seems a little odd, since they are not very close to the path of the exhaust system under the car.
  8. pasadena_commut
    1,482
    445
    Southern California
    Sorry for not being more specific. It is big, protruding, and a bolt, but yes, it is the head and not the tip.
  9. sam spade 2
    7,035
    2,788
    2017 Prius c
    It obviously is something that has been added.
    As such, nobody here will really know.
    Why are you not asking the shop(s) that worked on it recently ??
  10. pasadena_commut
    1,482
    445
    Southern California
    I am waiting for a reply on that from the service department that replaced the cat and installed the cat shield.
    If it wasn't them then there would be no way to find out. The car was bought used and all the previous work would have been either in the engine compartment or under the dashboard.
  11. SweetPeaPrius
    SweetPeaPrius New Member
    Walnut, ca
    Did you ever figure it out? I have the same holes in my 07 prius and would like to know if they could be used to ground an amplifier. Thanks.
  12. pasadena_commut
    1,482
    445
    Southern California
    Nope, never figured it out.
    It would probably work as a ground but better I think to ask that specifically in the "Gen 2 Prius Audio and Electronics" forum. Since it is far from both the dash perhaps best to measure resistance back to the negative post on the battery. Then do the same at some bolt under the dash. If the values are close it should work OK as a ground. If the bolt value is significantly higher, like >30 vs. 2 Ohms, perhaps there might be some issues.
