Hole plug
Discussion in 'Gen 2 Prius Technical Discussion' started by fkat, Nov 14, 2021.
  1. fkat
    fkat Junior Member
    22
    Cary, NC
    I got this hole plug part 90333-30008 (basically a sticker) to cover the hole on the underside of my gen 2. It looks like a sealant or some undercoat was brushed over it. Does anyone know or recommend what I should use to do this? I have a black 3M rubber spray can but don’t think I want to spray here.
    This is the hole
  2. Tombukt2
    Tombukt2 Senior Member
    13,405
    2,415
    Durham NC
    It looks like a plug from where the spare tire well will fit there if that's the case just order one of those and stick it in there or you measure the hole and you get a push-in rubber plug for that size hole or put a piece of zip tape over it
    SM-A715F ?
