Holes in cabin air filter
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tookiewana, Dec 2, 2009.
  1. Tookiewana
    Tookiewana New Member
    Morgantown, WV
    I checked my factory cabin air filter today and in addition to a large amount of debris, there were holes in the filter. I am definately going to replace it with a better filter, maybe the Fram. Anyhow, I am wondering if it could have caused any damage to the AC system or anything else if debris went right through the filter.
  2. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    I changed my Gen II cabin filter every 10,000 miles. The filter was dirty with some debris, but never any holes. Sounds like you may have a visitor that found a home in your car for the winter.
  3. richard schumacher
    7,680
    1,059
    United States
    Most likely mice. See boo's post below for very helpful pointers on screening, which may reduce the problem.
  4. Tookiewana
    Morgantown, WV
    I agree. There was a ball of soft material (thread/lint/etc) all wad up in about the size of a baseball. Could the holes in the filter have caused any damage to the AC system if debris got sucked through it?
  5. Politburo
    Politburo Active Member
    971
    208
    If appropriately sized debris of an appropriate material were introduced, yeah, it's possible. I don't think it's likely, though. You'd have heard any such debris moving around the system.
  6. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    You can screen-off the largest and most likely entrance holes for mice and other rodents. The holes are under the windshield wipers and plastic cowl on the bottom of the windshield.
    This file has the best easy-to-follow instructions and pictures for removing the windshield wipers and cowl:
    [​IMG] BT Tech Strut Tower Brace Install - By GadgetDad (Lee) v2.doc
    After you remove the wipers and cowl, you can screen-off the several small and large openings to help prevent mice from entering the cabin. Mice have been known to especially like building homes in the cabin filter area.
    I had to remove the wipers and cowl when I was installing my strut tower brace. While the wipers and cowl were removed I decided to do a quick and dirty screening job using what I had readily available which were vinyl double-screened gutter guards and tape (the best or better screening job would use metal screens and screws). Here's a pic:
    And here's the thread with pictures showing the best or better way to screen-off the openings in both the front and the rear hatch areas, using 1/4 inch metal screens and self-tapping screws:
    http://priuschat.com/forums/knowledge-base-articles-discussion/51005-mouseproofing-prius.html
  7. tochatihu
    tochatihu Senior Member
    9,866
    3,819
    Kunming Yunnan China
    2001 Prius
    The world's small rodents take a dim view of this type of Prius mod, and they will stick you with bubonic plague or Hantavirus if given a chance. So watch it.
  8. mike lipke
    mike lipke New Member
    89
    MN
    Even worse, they will never let you become a Disney star.
