Home air pump?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by coolio10, Dec 8, 2010.
  1. coolio10
    coolio10 New Member
    DC
    Any of you guys have a home air pressure pump? did a search on this subforum and nothing came up. Found a thread here about someone considering grill blocking and he used a bicycle pump. Is this acceptable?
  2. fuzzy1
    10,150
    Search for 'air compressor' if you want an electrically powered pump.
    Yes, muscle powered bicycle pumps are fine. Use the floor pump variety, as the smaller hand or frame variety that cyclists carry while pedaling are much too slow.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    For everyday car use, I have a 12V jump box that I carry in the back of my Prius. It does nicely for topping the tires, and is handy if you need to jump start someone else's car, or even your own Prius.
    For bigger jobs I have a smallish 120V portable compressor and a larger tank model.
    It all depends on your needs? What is your intended application?
    Tom
  4. don_chuwish
    don_chuwish Well Seasoned Member
    816
    182
    Southern Oregon
    I have a Porter Cable pancake compressor that works well. Got it for nail guns and light paint spraying but with the side benefit of tire pressure top offs. Once you have a compressor in the house you never get tired of finding ways to use it.
    This one's similar to what I have, but nicer looking:http://www.amazon.com/dp/product/B000O5RO1Y?tag=priuschatcom-20 D
  5. DumbMike
    DumbMike Active Member
    560
    119
    Los Angeles
    I too have a Porter Cable pancake compressor and it works well. However, I'm not sure I'd spend $150 on an air compressor solely to pump up my tires. If you want an air compressor solely for that purpose, I'd go to HarborFreight.com and get one of their $60 pancake compressors. But, if you will use it with a nail gun, etc., then I'd spend the extra money for a better quality product like the Porter Cable compressor.
    Mike
  6. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    This is what I use at home.
    Here is a pic of the garage I keep the Prius in.
    Garage Picture
  7. TonyWilkey
    TonyWilkey Member
    99
    25
    Kansas
  8. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    And advantage to a compressor with a tank and water drain on the tank is that moisture condenses in the tank and you can drain it out. With a bicycle type pump or a 12v car pump without a tank, all the moisture that was in the air gets pumped into your tires and can condense there.
  9. qbee42
    18,058
    3,074
    Northern Michigan
    This is a very good point. The air out of a tank isn't dry, but it's a lot drier than straight from the compressor.
    Tom
  10. bisco
    49,376
    man, that is sweet! you must clean it every week, you could eat off of that floor.:)
