Home Brew GPS
Discussion in 'Gen 2 Prius Audio and Electronics' started by nyconrad, Sep 20, 2006.
  1. nyconrad
    nyconrad Cconrad in Virginia
    222
    Powhatan, Va
    Home Brew GPS
    I have seen lots of postings about after-market GPS systems, both installed and portable, and decided to post my solution.
    I have used PDA’s for years and find they can be extremely versatile.
    PARTS NEEDED:
    PDA - I use the Palm T5. I tried using a LifeDrive but find that the BT connection times out when I use it to go online with my Verizon e815. The screen is large and bright enough to see as long as it is not in direct sunlight.
    MAPPING SOFTWARE - I use TomTom software. It provides voice directions, re-routing when you go off-track, and you can easily find POI (including gas stations) on the fly.
    HOLDER
    – I use the suction base holder for the Palm that lets you attach to the windshield or it works really well on the cup holder cover on the center console. It has an 8†flexible stem that allows for easy positioning.
    CABLES – You can get a Y power adapter that will charge and power the PDA and the
    GPS DEVICE – I use a Holux BT GPS device so I don’t have to have the cable connected to the Palm every time I use it for short trips. You can get on EBay for about $60. I start it on the dashboard so it gets a good view of the sky, and after it locks into the sat signals I can just drop it in the center console and it works fine.
    I find this the perfect solution for me. A dedicated GPS unit is just that – a GPS unit. With the PDA I still have all the functionality as before. It can even substitute for an MP3 player in the car. A one-stop solution!
  2. mitchbf
    mitchbf New Member
    105
    Chicago Area
    I have the factory GPS system in my Prius but I recently bought a Garmin IQue M3 for travelling and I've just come back from my first trip with it. It is a Pocket PC with a built-in GPS antenna and receiver and comes with a windshield mount which plugs into your lighter and mapping software. The software is really great and the whole unit really worked well. If you search for a place under a category, it even comes up with the telephone number. I've previously used a laptop with an antenna and this beat that hands down. It is definitely an economical way to add a GPS and it gives you all the functionality of a Pocket PC as well. I can listen to MP3s, watch video, manage my contacts and calendar and still have a dedicated GPS all for under $300... :)
  3. nyconrad
    222
    Powhatan, Va
    <div class='quotetop'>QUOTE(mitchbf @ Sep 20 2006, 03:57 PM) [snapback]322403[/snapback]</div>
    Glad it worked so well for you. That was exactly my point! Even if someone has an existing PDA, there are options to upgrade it for GPS use that works just as well, if not better, as the GPS hand-held units that people are buying. And at the same time have all the extra functionality of the PDA.
  4. PriusInsight
    PriusInsight New Member
    89
    Which holder did you use? Many PDA holder suction cups are too large to use with the front cup holder cover.
    I use a Nuvi 350 and it works very well there...
    The RAM Mount suction cups are too large.
    One nice option is the RAM A CAN from RAM Mounts. It modifies a standard 12 oz soft drink can (full and unopended) by attaching a cup to the can, the can then sits in the cup holder. The other side of the can has a cup with an attachment point for RAM Mounts brackets.
    I used it wih a Garmin iQUe for a while...
    <div class='quotetop'>QUOTE(nyconrad @ Sep 20 2006, 04:09 PM) [snapback]322383[/snapback]</div>
  5. BobZ
    BobZ New Member
    323
    Long Island, NY
    Garmin GVN 52 interfaces with the factory MFD
  6. nyconrad
    222
    Powhatan, Va
    <div class='quotetop'>QUOTE(BobZ @ Sep 28 2006, 06:33 PM) [snapback]325273[/snapback]</div>
    My point was that you do not have to BUY a dedicated GPS if you already have a pda.
  7. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    Aren't PDA-based GPS units extremely slow at computing routes compared to a normal mobile GPS? That's been my experience. A car GPS is designed to be plugged in most of the time, so they don't have to use the low power consumption (and slow) CPUs that are in PDAs.
  8. BobZ
    BobZ New Member
    323
    Long Island, NY
    Many people with non nav cars are dying to tie into the MFD. Now there is a solution
  9. sl7vk
    sl7vk Member
    518
    23
    Salt Lake City
    <div class='quotetop'>QUOTE(BobZ @ Sep 28 2006, 06:47 PM) [snapback]325284[/snapback]</div>
    You're right. And keydiver is going to try it out.... In the interim I think I'm going to buy the Garmin c320, and once I find a good way to integrate the GVN 52, I'll upgrade and give the wife the c320.
  10. nyconrad
    222
    Powhatan, Va
    <div class='quotetop'>QUOTE(priusenvy @ Sep 28 2006, 06:45 PM) [snapback]325283[/snapback]</div>
    OK. I agree with you all.
    If you bought the car with the GPS option - use it!
    If you want to buy a dedicated GPS unit - by all means, go out and buy it!
    If you like printing out directions from Mapquest - go for it!
    To make it clear. I did not start this thread to argue the merits of one GPS versus another. or the benefits of tying GPS into the MFD, or which GPS is the best one to use.
    If you own a PDA, there exists the ability to use it as a GPS in your car.
    Is it the best GPS solution on the market? NO
    If you own a PDA and do not want to go out and spend a couple of hundred bucks on a GPS, here is a way to use it as a GPS. When you walk out of the car with the PDA in your pocket it retains all of the functions of the PDA and you have use for it in another application.
  11. nyconrad
    222
    Powhatan, Va
    Yes.
    It takes about 30 seconds from a cold start for the GPS to lock into the sats. I enter the destination before I walk out to the car, plug it in and as soon as it finds the sats it becomes active. On my setup, it only takes a couple of seconds for it to compute the route. When off-track, it recalculates in about 3 seconds. It's not worth setting it up on a daily basis just to see where I am on the road. I use it when I'm going someplace that I don't know how to get to, or for trips away from home. At a rest stop, or when I get to where I'm going, I don't even bother to turn them off if I'll be back in the car after a couple of hours. (unless I need the PDA for other things) I just take it out of the holder and drop it in the console. The PDA stays bonded with the GPS and I avoid the 30sec cold start.
  12. nyconrad
    222
    Powhatan, Va
    I just checked out the specs of the Garmin GVN 52. Appears like it would work great in the Prius as a GPS that integrates with the MFD, but it sounds like it will make a really lousy PDA. (and pretty hard to slip into your pocket or use in a rental car when away on business trips)
  13. sl7vk
    sl7vk Member
    518
    23
    Salt Lake City
    <div class='quotetop'>QUOTE(nyconrad @ Sep 29 2006, 12:16 PM) [snapback]325616[/snapback]</div>
    LOL.... Nobody is objecting to your setup... Sounds pretty good actually. Out of all this, I've decided to get either the Nuvi 350 or the c320..... I think a non-integrated setup will work pretty good for me for now.
    My problem is that I can't stand PDA's. My old man gave me one when I graduated from college, and I used it about 3 times.
  14. BobZ
    BobZ New Member
    323
    Long Island, NY
    <div class='quotetop'>QUOTE(sl7vk @ Sep 29 2006, 12:45 PM) [snapback]325630[/snapback]</div>
    Agreed. No one's knocking your set up or idea. Just hashing nav optoins is all
  15. keydiver
    keydiver New Member
    509
    Hobe Sound, Florida
    <div class='quotetop'>QUOTE(nyconrad @ Sep 20 2006, 03:09 PM) [snapback]322383[/snapback]</div>
    This was actually my preferred way to add a GPS to my Prius, except the TomTom won't work with my Cingular 8125. I don't know why, as it runs Windows Mobile 5.0, but their tech support at TomTom was anything but helpful.
    The downside of the Garmin GVN 52 I ordered is, as someone else mentioned, that it won't be usable outside the car, so I won't be able to take it hiking/biking. :(
