Home charger recommendations
Discussion in 'Prime Plug-in Charging' started by JEFF STEIN, Oct 2, 2020.
Tags:
  1. JEFF STEIN
    JEFF STEIN New Member
    NEW YORK
    2020 Prius Prime
    Any recommendations for a home weatherproof battery charger for a 2020 Prius Prime?
    49,523
    amazon, ebay, cheapest you can find. duosada? the basic ones are all the same. if you want data/wifi capability, you move into another stratosphere
    Raytheeagle and jerrymildred like this.
  3. Salamander_King
    Salamander_King Senior Member
    10,975
    8,870
    New England
    Are you looking for an L2 EVSE for a 240v outlet? OEM L1 (120v) that came with the car is weatherproof. I use it outside all the time.
  4. jerrymildred
    jerrymildred Senior Member
    11,516
    14,120
    Tampa, FL
    The charger is under your back seat. What you're looking for is an EVSE.
    The best EVSE is the one that meets all your needs. I just use a cheap Duosaida. AFAIK, they are all weatherproof. I can't improve on what @bisco and @Salamander_King already said.
    Salamander_King and Raytheeagle like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    I found my work charger on Craigslist :).
    Here's our setup as there is another Prime and Leaf that charge using the Ford cords I got ;):
    Many different ways to accomplish the goal(y).
    Salamander_King and jerrymildred like this.
