Home electric outlet?
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, May 5, 2024.
  1. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,136
    1,573
    Iowa
    Hi Y'all: Been awhile, have some physical things I am working on defeating.
    Anyway, baby steps, but I need to replace a 120-volt electrical home wall outlet. It is what is called a "switched" outlet, In this, the top plug-in is controlled by a wall switch and the second plug-in in this outlet is hot all the time,
    I have googled and think I am all set, but a little leery -- here goes...
    To replace this, I just need a "regular" 15 amp wall outlet, correct? No special outlet?
    BTW, I freaked when I turned the power off at the panel and saw "strawberry jam" leaking out around the breaker switch -- Google answered that question -- dielectric grease.
    Kris
    bwilson4web likes this.
  2. ChapmanF
    15,503
    Ok, you take a "regular" 15 amp duplex wall outlet, and you look closely at its sides, where the terminal screws are, and you should see both an upper and a lower pair of screws.
    In normal use, you'd have one wire pair coming in, and it doesn't matter whether you connect to the upper or lower screw pair, because you can see a copper plate beneath the screws on each side that connects upper to lower with a breakable tab.
    For your situation, you'd start by assessing the wires coming into that box. Have you got two distinct pairs, one bringing always-on power and one bringing switched power? Or have you got a 3-conductor cable coming in, a single common white, then something like a black and a red, one being the always and one being the switched?
    So you'll want to break off the tab on the hot (brass-colored screws, narrow slots) side of the outlet in any case, so you can connect the switched hot wire to the top screw and the always hot one to the bottom screw.
    If you have just one shared neutral, you'll leave the tab unbroken on the outlet's neutral (silver-colored screws, wide slots) side, and connect that shared neutral to either the upper or lower screw. If you have one neutral for each hot, you can break that tab too and wire that side the same as the other.
    ETC(SS), bwilson4web and cyberpriusII like this.
  3. cyberpriusII
    1,136
    1,573
    Iowa
    GREAT explanation! I thought there was a "trick" to it, but a couple of web sources did not explain it...of course, I may have been looking at the wrong stuff.
    Well,off to try it. If you don't hear from me again.....:whistle:
    kris
  4. Mendel Leisk
    38,662
    ^ That alone has worked for me so far. Look at what's going on with the existing one, take copious pictures and sketches, duplicate it.
    If you don't want to be swearing, get a old-school outlet (if at all possible), NOT a tamper-resistant version:
    Just need to vent... | PriusChat
  5. cyberpriusII
    1,136
    1,573
    Iowa
    Yeah, I saw those TR outlets. When I first saw them, thought TR was a brand name. Luckily I had three OLD outlets stashed away that have never been out of their Leviton boxes....don't ask, 'cause I can't tell you why, but they have been stashed in clothes dresser "unmentionable drawer." :unsure::eek:
    I have trouble with the switches installed near water -- they are next to impossible to get plugs into...but I seldom use them, so....I would like to swap out that switch I mentioned earlier, but my old golden retriever is sleeping next to it and I don't want to disturb her. I might open the refrigerator, that usually works,:)
    kris
    #5 cyberpriusII, May 5, 2024
    ETC(SS) and Mendel Leisk like this.
  6. cyberpriusII
    1,136
    1,573
    Iowa
    Success, sort of....but not really....outlet really does not work now.
    I got the dog moved and replaced the outlet. Plugged in a 7 watt night light, just to check and it barely glows, just the filaments turning a very low orange color. Plug the night light into the next outlet in the line (same circuit) and it is light and bright. Plug it into the next outlet in the circuit up the line and night light is fine. Tried both outlets on the new outlet.
    Originally, a floor lamp in that outlet was flickering, but I found out the plugs were "hardly" in the outlet---they were very loose, so thought the problem was the outlet. The dogs tend to sleep in that area and figured 100s of pounds of dogs over the years knocking into it....
    Took the floor lamp out last fall and had not used the outlet since, until today.
    Thoughts?..
    kris
  7. ChapmanF
    15,503
    Sounds as if there is a(t least one) very poor connection between the wiring and your new(ly installed) outlet.
    Did you end up having a hot/neutral wire each for the always and switched halves, or just a hot for each and a shared neutral?
    If just a shared neutral, I would look at that connection first, as it would explain the light being dim in both halves of the newly installed outlet.
    Can you post photos of how you wired it?
    Did you wrap around the screws, or push-wire it, or back-wire it? (Back-wire is only on some outlets; it's like push-wire in that you just insert the wire end straight, but beneath a plate that's tightened by the terminal screw, instead of just into a pokey thing. Non-back-wire outlets don't have those plates. Back-wire is my favorite when the outlet has it; the pokey things are my least favorite.)
    For how long have those old outlets been living in the unmentionable drawer? Sometimes, with long storage, metal terminal surfaces can get very oxidized, without looking that way.
  8. cyberpriusII
    1,136
    1,573
    Iowa
    There was one white wire on the silver side and a red and black wire on the brass side. A green ground.
    Broke tab on the brass side. I don't "back stab" wires, but these outlets sort of have something like that.I think it is what you are calling back-wire.
    There are brass (?) clamps under the screws on the sides of the outlets. Normally (?) you would wrap wire around the screws and tighten down. With these plates/clamps you poke the wire under the clamps and tighten down the screws on the clamps. All the outlets I buy are like that. I yanked hard on all wires, red, black and white and none of them budged from under the clamps. Ground was a normal wrap around screw type of thing.
    Not sure how long the outlets have been around. Maybe 10 years, but always "undercover" in original boxes:LOL::LOL:
    Really don't know how they ended up in the underwear drawer???
    Maybe should have tested before I put it all back together. Posted below the pix
    kris
    #8 cyberpriusII, May 5, 2024
  9. cyberpriusII
    1,136
    1,573
    Iowa
    O.K. could not stand it, Here they are
    kris
    BiomedO1 likes this.
  10. ChapmanF
    15,503
    I might take it off again and shine up the ends of those wires (special attention to the white one) until they have a nice bright copper appearance. Ordinary steel wool will shine up copper wires a treat. (Just clean up well so there isn't any steel wool fuzz left around when you reconnect.) When you've tightened up those back-wire clamps a little but not fully, you can twist and push-pull the wires a little to maybe rub through any oxidation in the outlet's clamps. Then go ahead and torque the screws down fully. And see if the night-light test goes any better.
  11. John321
    John321 Senior Member
    1,199
    1,198
    Kentucky
    From your pictures it looks as if all your connections are in the correct place.
    You seem pretty handy.
    Do you have a volt/ohm meter?
    It might be worth your time to check the actual voltage to the outlets.
    The best way to do this is - disconnect the wiring to the outlet with power breakers turned off - then turn power on and carefully check for 120 volts between the black and white wire and then 120 volts between the red and white wire.
    If no 120 volts or any odd voltages - you need to check the power breaker/switch or any connection in between the outlet and the power source to track back the problem.
    If you have 120 volts at the wiring to the outlet, you have a bad connection on the outlet you are installing or potentially a faulty outlet.
    Of course a person needs to be careful and confident observing safety procedures working around electricity!
    You may find this video helpful, this is a no nonsense, low key, factual way to troubleshoot a circuit that is easily understandable made by an electrician
    #11 John321, May 6, 2024
  12. BiomedO1
    BiomedO1 Senior Member
    1,446
    790
    SacTown, Ca
    Yea, you need to find or buy a cheap outlet tester and voltage tester. Sounds like you've low voltage through a bad connection someplace. I wouldn't rule out the circuit breaker in your fuse box, due to the strawberry jam. Circuit breakers are designed to fail in the open position, for obvious reasons. Check the other outlets this circuit is connected to. If your getting 120 VAC at those other outlets, one of those relay wires may be loose. Very obvious, they usually fall off as soon as you pull the outlet out of the electrical box. Tighten the loose wire back into the appropriate spot and your done.
    Good hunting.....:p
