HOME LINK REAR VIEW MIRROR
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DSB, May 16, 2007.
  1. DSB
    DSB New Member
    My Prius is an '06, Option 6.
    Has anyone figured a way to keep the mirror from moving after pressing one of the garrage door operner buttons? I've had it back to the local dealer and he says he has tightened the clamp (screw) but beyound that there is nothing he can do. It stays tight for a few days and then needs to be retightened. Does anyone have a REAL fix?
  2. aaf709
    3,862
    2022 Prius Prime
    I put my hand behind the mirror so it's more squeezing rather than pushing.
  3. mpgFanatic
    mpgFanatic New Member
    112
    <div class='quotetop'>QUOTE(DSB @ May 16 2007, 11:05 AM) [snapback]443336[/snapback]</div>
    If I understand the problem, and it relates to how often you are able to screw, then I would suggest Viagra. If you need some sources, just drop me a line. According to my email inbox, I am on the A List.
  4. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    [rimshot]... that Viagra comment was really reaching. As far as I can tell the only motivation there was the word "screw." :rolleyes:
    Anyway, aaf709 uses basically my method: I push the button with my thumb, but hold the mirror in place with my fingers, so basically squeezing the mirror so it doesn't move.
    It seems like a pretty strange design, considering how hard you have to press the buttons, and you have to hold them down for a second or two as well.
  5. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    :rolleyes: That's why I use the IGNORE function for some forum members.
  6. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(Charles Suitt @ May 16 2007, 11:38 AM) [snapback]443540[/snapback]</div>
    No one cares!!! :rolleyes:
